Results 1 to 11 of 11
Thread: Marine sealants????
05-01-2019, 10:27 AM #1
Marine sealants????
Want some opinions on marine sealants, cant find the answers im looking for with the search function so here it goes:
So before I bolt up my new power head I figure I might aswell tear down the transom and reseal all hardware. Question is what sealant will work the best? based on the information I can find the 3M 400UV should cover all my needs, ie: transom bolts, tow hooks, cleats, plastic seam cap, etc. what everyones opinion??? is 4000 the best all around choice? or should I get some 4200? does 5200 have any application here? any input would be appreciated.
05-01-2019, 11:01 AM #2Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
4000 uv is the newest stuff. Should be very good since it has uv protection and is a poly. Just never use silicone.
05-01-2019, 11:04 AM #3
well i know better now, just wish i did back when i put it all together. Gonna have alot of cleaning to do... and i really dont wanna have to worry for a couple 5 years.
05-02-2019, 01:51 PM #4
I only ever use 5200. Stuff is gold in the boating world. Lots of little pieces of paper towel to wipe away excess. Or if you're doing long joints, you can lay down masking tape first, on both edges of the joint, squeegee it in with a credit card or plastic spoon, or your finger... then peel the masking tape up, and you get an absolutely perfect edge.
1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
tnelsmn liked this post
05-02-2019, 03:36 PM #5
I’ve seen it said in many places that 5200 is damn near permanent so if you want to ever take it apart don’t use it. Also it has poor bond to plastics and can even erode plastics. As per the data sheet 4000 appears to be the better universal choice but I always like to hear real world opinions.
05-03-2019, 05:20 PM #61) 1995 14' Bayliner Restoration <--Click
05-03-2019, 05:29 PM #7Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
Use the primer and correct procedure and it is permanent.......It will rip the gell coat off the fiberglass laminate if you remove something.
05-03-2019, 06:25 PM #8
Boat Life makes some good sealants that we like to use. PS if you keep 5200 in the freezer after opening it, it will last a long time.
XstreamVking, tux974 liked this post
05-22-2019, 07:53 PM #9Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1267
- 368
There is a release agent for 5200 5215 maybe came in small squirt bottle score and spray and will release.
05-22-2019, 08:18 PM #10
07-03-2019, 02:28 PM #115000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
37th Annual Dania Beach Marine Flea Marine Market
By FUJIMO in forum General Boating DiscussionReplies: 2Last Post: 03-06-2015, 12:18 PM -
Flexible thru hull sealants
By Carter Powell in forum Technical DiscussionReplies: 13Last Post: 01-08-2012, 09:50 PM -
OMC sealants
By SteveO in forum Technical DiscussionReplies: 5Last Post: 10-25-2005, 12:34 PM
