Results 1 to 11 of 11
    Apr 2015
    saskatchewan
    Marine sealants????
    Want some opinions on marine sealants, cant find the answers im looking for with the search function so here it goes:
    So before I bolt up my new power head I figure I might aswell tear down the transom and reseal all hardware. Question is what sealant will work the best? based on the information I can find the 3M 400UV should cover all my needs, ie: transom bolts, tow hooks, cleats, plastic seam cap, etc. what everyones opinion??? is 4000 the best all around choice? or should I get some 4200? does 5200 have any application here? any input would be appreciated.
    4000 uv is the newest stuff. Should be very good since it has uv protection and is a poly. Just never use silicone.
    Apr 2015
    saskatchewan
    well i know better now, just wish i did back when i put it all together. Gonna have alot of cleaning to do... and i really dont wanna have to worry for a couple 5 years.
    Rhode Island
    I only ever use 5200. Stuff is gold in the boating world. Lots of little pieces of paper towel to wipe away excess. Or if you're doing long joints, you can lay down masking tape first, on both edges of the joint, squeegee it in with a credit card or plastic spoon, or your finger... then peel the masking tape up, and you get an absolutely perfect edge.
  5. Likes tnelsmn liked this post
    Apr 2015
    saskatchewan
    I’ve seen it said in many places that 5200 is damn near permanent so if you want to ever take it apart don’t use it. Also it has poor bond to plastics and can even erode plastics. As per the data sheet 4000 appears to be the better universal choice but I always like to hear real world opinions.
    Rhode Island
    Quote Originally Posted by derpid View Post
    Permanent?! nah. Not on engine bolts through a transom anyway. That's what a hammer and 3/8" extension are good for. Banging them out lol.
    Use the primer and correct procedure and it is permanent.......It will rip the gell coat off the fiberglass laminate if you remove something.
  9. Likes TwzteD, tux974 liked this post
    Boat Life makes some good sealants that we like to use. PS if you keep 5200 in the freezer after opening it, it will last a long time.
  11. Likes XstreamVking, tux974 liked this post
    Miami,Fl
    There is a release agent for 5200 5215 maybe came in small squirt bottle score and spray and will release.
  13. Likes tux974 liked this post
    Moline,Ill
    Quote Originally Posted by delawarerick View Post
    I would use 4200, been there, done ^ this
    is gone
  15. Likes tux974 liked this post
  16. #11
    Mar 2016
    cincinnati, ohio
    Splain it Lucy, why never use silicone???? GE used to make a black adhesive/sealant that I used on everything, but it was kinda free, stole it from the crib, don't repeat that.
  1. 37th Annual Dania Beach Marine Flea Marine Market
    By FUJIMO in forum General Boating Discussion
    Last Post: 03-06-2015, 12:18 PM
  2. Flexible thru hull sealants
    By Carter Powell in forum Technical Discussion
    Last Post: 01-08-2012, 09:50 PM
  3. OMC sealants
    By SteveO in forum Technical Discussion
    Last Post: 10-25-2005, 12:34 PM
