Results 1 to 5 of 5
Thread: Fuel Injector
04-30-2019, 08:23 AM #1Junior Member
- May 2016
- Norh Miami Beach Florida
- 7
Fuel Injector
Smartcraft gauge alarm went off, shows injector failure, could it also be a coil?
04-30-2019, 10:33 AM #26000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Swap the bad inj with a good one and see if the code follows
04-30-2019, 11:12 AM #3Junior Member
- May 2016
- 7
04-30-2019, 11:18 AM #46000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Without the dts it’s an ohm resistance fail. Should be able to ohmmeter the injectors. Think it’s 1.8ohm +- .01ohm
if you find one out then you can swap. Could also be in harnes if one worked loose if none ohm bad.
05-01-2019, 08:39 AM #56000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Yamaha Fuel Injector
By crimson merc in forum Parts WantedReplies: 1Last Post: 09-03-2015, 09:44 AM -
Leaking Fuel Injector hose from rail. Need to replace injector?
By nburgart in forum Technical DiscussionReplies: 6Last Post: 08-26-2014, 12:57 AM -
fuel injector cleaning
By TEXAS20225 in forum Technical DiscussionReplies: 6Last Post: 08-17-2012, 08:04 AM -
anatomy of a fuel injector
By boilerdawg in forum Technical DiscussionReplies: 1Last Post: 06-20-2009, 12:56 PM -
fuel injector question
By blackcloud in forum Technical DiscussionReplies: 5Last Post: 05-14-2004, 10:12 AM
