Results 1 to 2 of 2
    Mar 2012
    Lake Hopatcong, NJ
    Need suggestions on how to re-route power trim hoses
    My boat has a Bob's jack plate along with a 2.5 with offshore clamp and Seastar tournament steering. Problem is, there's no good way to route the stock power trim hard lines so that the engine can still trimmed and the lines don't collide with the steering ram when trimmed up. And then if I want to lower the jack plate the hoses will hit the transom and make it worse. Anyone ever cut the hard lines to shorten them? Or maybe come out from the side with flexible hose? Looking for ideas or pictures of how others handle it.
    What kind of flare do these lines use?
    Attached Thumbnails Attached Thumbnails IMG_1851.jpg   Screen Shot 2019-04-29 at 9.35.10 PM.png
    Pekin, IL
    Looks like someone straightened them a bit. Bend them to either point downward or off to either side. Be very careful bending as they kink really easily. Also if I remember correctly you can change the length by using brake line form the auto parts store.
    Rock
    Team Junk
  1. Trim or grommets for Mercury remote trim pump hoses
    By TraceF3 in forum Technical Discussion
    Last Post: 04-08-2018, 12:01 AM
  2. robby ,shes ready to go !!! route 66 power tour!!!!!
    By PARKER RABE in forum The Scream And Fly Lounge
    Last Post: 09-01-2015, 06:24 PM
  3. Ever seen trim hoses that don't disconnect from the trim bracket?
    By WATERWINGS in forum Technical Discussion
    Last Post: 11-24-2009, 08:56 PM
  4. Mercury Tech: Power Trim Problems...Any Suggestions?
    By imtwink in forum Technical Discussion
    Last Post: 03-29-2009, 12:53 AM
  5. more power ant suggestions
    By dotz in forum Technical Discussion
    Last Post: 06-22-2004, 07:19 PM
