Results 16 to 30 of 34
05-01-2019, 10:00 AM #165000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
This might be the fix. Just need to figure out what O-rings are needed. Or if the part number I posted earlier will work.
https://www.screamandfly.com/showthread.php?172770-87-3-Ram-Tilt-Trim
05-01-2019, 04:41 PM #175000 RPM
- Jun 2014
- South Carolina
- 161
- 28
- 13
- 59
- 54
05-01-2019, 07:30 PM #18The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
05-01-2019, 08:47 PM #19Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
One of the short rams has a valve or O ring that gets snotty......so I have been told. If any one.... CHAZ.... needs 1...2....3 rams.... I need to clean out my yard ..... Help.... will load and ship......Just hate to send to China.....
05-01-2019, 10:43 PM #20
Yes sir , I'm sure we can work out some kind of deal ..
I'll PM you my Info ..
A lot of the cores we have been getting lately have had that new "salt-oil" in em ..
I'm down to only a few good closure caps. If someone doesn't send in a good one with their cylinder I have to have the Mrs turn all the rot out , I fill them in and she has a set of cutters that a tool and die maker here in town made up for us that cut's the O-ring , dust seal and snap ring seats . Can't buy em new .. and it's quite a bit of work to bring one back from the dead ..
05-02-2019, 07:49 AM #215000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Last night I removed the trim motor. I ran into my first snag. I removed the 5 bolts shown and I am not sure what to do now. My motor does not look like the one from the link I posted. Just below that center hole is a spot where you can stick an allen key down and turn something that never gets tighter or looser, I am assuming this is turning the motor itself because fluid comes out of either hole beside it depending on the direction you spin it
05-02-2019, 09:17 AM #226000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
05-02-2019, 10:03 AM #235000 RPM
- Jul 2008
- Canada
- 112
Mine was leaking and was soft and I couldn’t bleed it. I put in a half of a bottle of hydraullic pump stop leak and topped it up and no leaks and solid. It was screaming like a bansheee and now sound great and works perfect.
05-02-2019, 10:52 AM #245000 RPM
- Jul 2008
- Canada
- 112
05-02-2019, 11:35 AM #255000 RPM
- South Africa
- 576
- 31
On the 3 ram system that falls.
After you have tried a new release valve and O rings
See Mercury parts diagram posted above
Part #9 , the Port Trim cylinder, has a bypass valve in it, to release the pressure when it reaches maximum Tilt.
That little check valve goes bad and is not serviceable. You will see that there is a little screen trying to protect it.
That is the cause of all your issues.
05-02-2019, 11:56 AM #265000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
So what’s the fix? Clean the screen? I guess I’ll pull that apart and look. Might try the stop leak suggestions if it doesn’t fix it. Still wondering if anyone knows about the pictures I posted above of the motor and valves in there. I can’t take it apart. I must be missing something
05-02-2019, 11:59 AM #275000 RPM
- South Africa
- 576
- 31
You may need to replace the Port Trim Ram complete
05-02-2019, 02:56 PM #286000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
05-03-2019, 10:03 AM #29The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
05-03-2019, 06:42 PM #305000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Didn't read through the whole post but twice on different trims I had a problem where they went down either relatively quickly or overnight, and all it took to fix it was to replace the o-rings below the filler cover. I forget the size but you should be able to get something close enough from an o-ring supply company in an industrial area probably a lot cheaper than going OEM.
Lower Unit Leaking Oil
By larsonblue in forum Technical DiscussionReplies: 11Last Post: 04-19-2010, 01:11 PM -
fixed trim tab angle
By Umassot50 in forum Props, Setup, and RiggingReplies: 2Last Post: 07-29-2009, 04:49 PM -
Mercury Tech: leaking lower unit
By red bullet in forum Technical DiscussionReplies: 3Last Post: 12-28-2008, 04:09 PM -
Trim Ram Unit Leaking, Anyone Know?
By dry3 in forum Technical DiscussionReplies: 6Last Post: 05-23-2007, 04:30 PM
