Results 1 to 13 of 13
    Big Rock, IL / Eagle River, WI
    Finally got the Circus Circus conversion done!
    I thought some of you might like to see the nitro to electric conversion I did on the Dumas Miss Circus Circus. I built the boat about 25 years ago and put a Picco 80 in it, I was never able to get it to run right, so it went on the shelf. I recently pulled it down and converted it to electric. .
    TP Power 4070/1090KV, 2-4S 70C Graphene pacs, Castle Mamaba XLX that I converted to water cooling. It was a tight fit getting everything in and keep it balanced...hopefully it runs good...we'll see
ID:	437474Click image for larger version.
ID:	437475Click image for larger version.
ID:	437477Click image for larger version.
ID:	437478Click image for larger version.
ID:	437479Click image for larger version.
ID:	437481Click image for larger version.
ID:	437482Click image for larger version.
ID:	437483Click image for larger version.
  2. Likes OnPad liked this post
    Sep 2002
    Solvang, Calif
    Nice!
    Gary
    Thanks, turned out to be a much larger project than I thought it would be...
    Sep 2002
    Solvang, Calif
    Question. The last two pictures... is that the speed controller and it's heat exchanger?
    Gary
    Yes, It started off as a Castle Mamba XLX...which is an ESC designed for rc cars. It comes packaged with an aluminum heat sink and cooling fan attached. I gutted it down to the the
    circuit boards and removed all the factory thermal compound. I then fabricated the 4 copper heat sinks with cooling tubes. They are also tin plate to stop any corrosion. The heat sinks are clamped to the four high current
    busses on the power circuit board with silicone based thermal compound between them. I also coated the circuit boards in Glyptal to water proof them. All this adds up to increasing it's current rating by almost a factor of two.
    approx.300 amps peak (stock form it is rated at 160amps). The Castle controllers, along with other mfg's have data logging capability. You can plot rpm, temp, voltage, ripple voltage, current along with a host of other settings.
    This has been a tremendous learning experience...the brushless motor technology has really evolved.
    Sorry for the long winded explanation....I guess "yes" would have sufficed
    Feb 2017
    Wixom lake michigan
    That sucker should rip! Looks very nice
    May 2001
    Maine
    I have a Miss Budweiser 1/8 I was thinking of doing the same retrofit to. It was set up with a .67 picco but now days electric or gas for me is the way to go
  9. #8
    Quote Originally Posted by 4Speed View Post
    I still haven't had a chance to run it, but I'm sure that will be a learning curve also. Should be interesting to see if it will run similar to nitro power.
    These older boats are pretty tight in the engine compartment, it took some doing to get everything installed and still balanced correctly. Mine is still a little tale heavy, may have to add some more weight up in the nose.
    Offshore Electric forum is a good place to go if you need help.They also have an online store that has been invaluable....real brick and mortar hobby shops are a thing of the past
  10. Likes OnPad liked this post
    Very nice conversion. Clean.
    1970 15' Allison/135 Chrysler stacker
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
    Nov 2001
    Lake Charles, Louisiana
    That is nice. What is the weight diff. between fuel and ele.?
    93 STV Mod VP/MERC 2.5 200
    Proverbs 4:18-20
    -- John F. Kennedy 1962
    I don't know for sure, but the hull with running gear and no motor weighed 9 lbs.
    I would guess the brushless motor is about the same weight as the Picco 80, maybe a little heavier. So the only additional weight is batteries and ESC. Batteries are about 1.3 pounds each... times two, and the ESC maybe weighs .25 pound
    Quote Originally Posted by CDave View Post
  14. #12
    Jun 2019
    GROVETOWN, GA
    Very nice! What did you use for the color of the boat, paint or vinyl ? Everything looks straight , all the outlines of the colors and cowling lines.
  15. #13
    Quote Originally Posted by KURYOU View Post
    Sorry, for the late reply.
    I painted the hull with two part epoxy paint. It needed to hold up to nitro fuel.
  1. The Pirate Circus Begins
    By transomstand in forum The Scream And Fly Lounge
    Last Post: 02-17-2011, 12:29 PM
  2. any nitro circus fans on here ???
    By PARKER RABE in forum The Scream And Fly Lounge
    Last Post: 01-09-2010, 12:11 AM
