Results 1 to 7 of 7
Thread: v8 merc 200hp
    Mar 2006
    auckland new zealand
    v8 merc 200hp
    Is the new 4stroke v8 200hp the same as a 300v8 as i have a 200v8 just looking to get a flash done.
    May 2001
    Ga
    I thought the 200 was v6 ??? Hf....
    Mar 2006
    200r SPECIFICATIONS - 200
    HP / kW
    • 200 / 149
    Engine type
    • V8
    MidSection
    • Conventional MidSection
    Displacement (CID/CC)
    • 279 CID
    Displacement (L)
    • 4.6L
    Cylinder Configuration
    • V-8 [64 degree] with Dual Overhead Cam [DOHC] and 32-valves
    Full throttle RPM
    • 5600-6200
    Air induction
    • Performance-Tuned Long-Runner Intake Manifold
    Fuel induction system
    • Electronic Fuel Injection (EFI) Computer Controlled with Advanced Range Optimization
    Alternator amp / Watt
    • 85-amp (1071 Watt) with Idle Charge
    May 2001
    Ga
    The 200’s we have sold have all been the new v6 . Didn’t know they offered it in an R model .
    Feb 2017
    Naples FL
    The 200hp has a different throttle body and tune.
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by half fast View Post
    The r and proxs is a v8
    Aug 2018
    On a racetrack or at the lake
    The 200hp V6 uses the same smaller throttle body as 200hp V8, the 250hp and up engines get the larger throttle body and 225hp and down get the smaller throttle body. According to the CARB reports the 200hp Pro XS V8 makes the same hp as the 225hp V6 albeit more torque and the 300hp Pro XS only makes 20 more hp than the 250 Pro XS model.
  1. 2.4 vs 2.5 200hp merc
    By mouse4x4 in forum General Boating Discussion
    Last Post: 06-17-2013, 10:23 AM
  2. Max rpm for a 93 200hp efi merc
    By Blown Challenger in forum Technical Discussion
    Last Post: 08-06-2012, 09:09 AM
  3. 98 Merc 200hp
    By 98_Nitro in forum Technical Discussion
    Last Post: 04-08-2008, 12:28 PM
  4. 200hp merc
    By ber1023 in forum General Boating Discussion
    Last Post: 09-04-2007, 08:21 PM
  5. your take on a Merc. 2.5 200hp efi
    By VoodooJim in forum Technical Discussion
    Last Post: 03-19-2007, 07:58 AM
