Results 1 to 8 of 8
Thread: 40 aamp to 16 amp 225 pm
04-24-2019, 09:02 PM #16000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
I HAVE ALITEWIGHT flywheel 16 a and a good 16 amp stator, how difficult would it be to change my pm to 16 amp system? dont run any accessories only gps. would it be fairly simple change? my electrical skills are limited. 5.-10 horses gain ive heard? its a 96 225 stock p max. thanks
04-25-2019, 04:54 AM #2
Not sure about HP gains..... It will just take weight off which= help the top of crank and top bearing.
You will need to modify your engine harness or get one from a 245/260 engine. Also install a rectifier and I like to use a 245/260 voltage regular. Some use 1 of your voltage regular from your 40amp setup.
Basically I suggest to copy the 245/260 engine electrical setup....JMPO
KIRCHNER thanked for this post
04-25-2019, 09:00 AM #3
Might spin up a little quicker, but only difference I noticed.
04-25-2019, 09:58 AM #45000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
Maybe I'm wrong I think I only changed flywheel, and stator, and unplugged 1 of my regulators, an works fine, but I've been drunk since then. Lol
04-25-2019, 02:34 PM #56000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
04-25-2019, 08:14 PM #6Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Been Drunk .... The EIF wants more Amp ......JMO.....
04-25-2019, 08:47 PM #7
04-25-2019, 10:06 PM #85000 RPM
- Jun 2014
- United States
- 153
- 7
- 30
- 42
It will be quicker and better on the crank. That’s all. You will have plenty of electrical capacity with the 16 amps, given your setup. Losing 6 pounds off your reciprocating weight is a really nice change. You have the parts. Go for it.
