Results 1 to 15 of 29
Thread: ARP Steering bolts
04-22-2019, 02:31 PM #1
ARP Steering bolts
OK, got me thinking about the steering bolt on my 300X, after reading the threads about bolt failures. What is the best source for the ARP steering bolts, or is there something better? I have the SeaStar Pro system.
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
Glasstream15 liked this post
04-22-2019, 02:58 PM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Pull it and inspect it. If in doubt get a new one from sea star. It's not very much green for peace of mind.
04-23-2019, 09:59 AM #35000 RPM
- Mar 2012
- Lake Hopatcong, NJ
- 218
- 31
Seastar HA5822 . They sell them all over. I bought one on Amazon
04-29-2019, 05:10 PM #45000 RPM
- May 2001
- Maine
- 983
- 35
- 42
- 171
I searched the part number and there is no mention of the bolt grade … like a grade 8 with the marks on the bolt head. Do you just assume that they are all high tensile as described and hopefully not "take offs" from across the pond. Any vendor marks to look for to ensure the quality.
04-29-2019, 05:12 PM #5Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
They have the ARP on the top.....They are hi grade stainless similar to a gr 8.
04-30-2019, 07:53 AM #65000 RPM
- Mar 2012
- 218
- 31
Yeah, the ones I have say ARP and then they either have initials for Teleflex or Seastar as well. The standard bolt has nothing on top.
05-16-2019, 03:38 PM #75000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
Anyone know how to get an ARP bolt set-up for my 91 Evinrude Looper steering?
05-17-2019, 06:26 AM #8Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
05-17-2019, 07:06 AM #9Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I don't know the specs but teleflex went to the trouble of sourcing some specialty fasteners so they must be up to the job. Gr 5 is close on standard 304, 316 etc., hi-po arp would bump up to near gr 8 ?. Stainless is cold hardened so an exact relation to heat treated steel is tough. Most stainless is numbered as to how it resists corrosion, not how strong it is.
05-17-2019, 07:48 AM #10Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
17-4 grades are for strength not corrosion, hence why omc used them for mounting v8's
phillnjack liked this post
05-17-2019, 08:25 AM #11Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
10-4........
05-17-2019, 08:43 AM #12Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I found a company that does bling bolts for harleys in the usa that does custom 17-4 and other high strength fasteners.
Very nice bunch of guys.
05-18-2019, 09:41 AM #13
The problem arise's when we identify materials some by their SAE or ASTM name while others we use a Brittish or Your-peein identification. The U.S. military even uses their own system of I.D.
What I might call a 304, 308, 316, 321, or a "630" others might call it "17-4 PH" because of it's 17% Chromium and 4% Nickel content and that it has been "Precipitation Hardened".
For the record, any material that contains 10% Chromium or higher is considered "corrosion resistant".
I'm not a metallurgist by any stretch. I refer to the AWS handbook when in doubt but the lower grades of stainless are Ferritic or Austenitic and have a low yield to tensile strength ratio. Higher numbered Martensitic and duplex concoctions have a higher yield percentage .. but it really takes getting into some really expensive mix's to reach that of other alloy carbon based steels.
What is the ARP steering bolt made out of .. ???
Heck if I know ..
But you can bet that they did their homework on stress analysis, shock loading, yield, tensile and elongation patterns from freezing to 100+ degrees before deciding on which material to roll threads onto ..
05-18-2019, 03:47 PM #146000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
13% for stainless
you also have to remember what load grade 8, 10.8 metric is tested for. Steer is a sheer load not holding a crank in and some ductability is good.
09-17-2020, 05:04 PM #157000 RPM
- May 2001
- Charlotte, NC
- 2,272
- 85
- 565
- 800
Bump for a good thread.
i recently bought a SeaStar Pro front mount h-steering. It came w- the ARP 3/8” x 1.35 INJF. Unfortunately, w- my application, the bolt is not long enough and ARP doesn’t want to sell me a longer one. Would a grade 8 Bolt be comparable to the supplied ARP bolt? Does UNF thread fit a UNJF thread?
Thanks for any help-
phillnjack thanked for this postphillnjack liked this post
Mercury bolts for shipping plate that locks steering
By kct11 in forum Technical DiscussionReplies: 1Last Post: 11-27-2016, 08:55 AM -
insuring against stuck bolts? torquing head bolts with marine grease?
By pcrussell50 in forum Technical DiscussionReplies: 26Last Post: 07-21-2015, 10:55 AM -
Mercury Tech: 2000 2.5 Pro Max/ Steering bolts sheered off
By Tgutie in forum Technical DiscussionReplies: 22Last Post: 03-25-2009, 02:03 PM -
removing omc steering arm bolts
By Ronny Jetmore in forum Technical DiscussionReplies: 16Last Post: 03-10-2004, 10:14 AM
