Results 1 to 2 of 2
04-22-2019, 10:40 AM #1
2.5 Small Shaft Sporty; LH Rotation; 1.87 Ratio
I'm sure this is hidden in the 1000's of pages on here but someone please enlighten my feeble mind.
I have one that won't stay in Forward. Sounds like the Dogs 'r Out!!!
I see you can now buy separate pinion and forward gears for the RH rotation units but found nothing for the leftys?
Am I right in concluding the leftys are only avail as a full set?
Also, I've been into many standard LU's, what differences can I expect on this Lefty?
Does anyone on here have any clean gears they'd turn loose of?Last edited by WillySteve; 04-22-2019 at 12:35 PM.
WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
04-22-2019, 03:37 PM #2
Never Mind Y'all....it's apart and parts ordered!
The single forward gear is NOT avail. from Pro MarineWillySteve Hendricks
What hub kit for small shaft sporty
By aggiestckl in forum Technical DiscussionReplies: 3Last Post: 06-07-2018, 01:16 PM -
Want To Buy 3.0 LH sporty 1 piece or 2 shaft length no matter... 1.62 small shaft
By vw-nut in forum Lower UnitsReplies: 0Last Post: 10-31-2015, 06:58 PM -
2 Mercury 15" 1.87 small shaft LU's 1 coned and 1 sporty RH rotation
By ddipert in forum Lower UnitsReplies: 5Last Post: 02-11-2015, 12:04 PM -
2.5 Left hand rotation sportmaster, 15" shaft, 1:87 gear ratio
By ebmarine1 in forum Lower UnitsReplies: 1Last Post: 09-03-2014, 01:41 PM
