Results 1 to 3 of 3
    May 2017
    Richmond, Virginia
    2001 200 Optimax 4 beep alarm
    Couple weeks ago got the Optimax 4 beep alarm every 2 minutes. Bit of research showed water in fuel separator or low oil in engine mounted tank. Replaced water separator filter. Still got 4 beep alarm. Engine oil tank full all along. Took engine mounted tank off and found magnet had separated from float. Installed new oil reservoir tank on engine; filled and bleed system. Still getting 4 beep alarm. Any further suggestions out there? Appreciate any feedback.
    Mike
    ft pierce fl
    Could be the water in fuel sensor that is bad. Older opti's have a single wire sensor in the spin on fuel filter on the VST. Newer opti's have a 2 wire sensor screwed into the VST housing. To check sensor, use OHM meter on the sensor.
    May 2017
    Richmond, Virginia
    Thanks, Bottom cylinder on passenger side let go while I had it on the hose in driveway. Pulled the spark plug and oil came pouring out. Love the boat, may re-power. Thanks for the input!!
  1. Temp alarm stopped its normal beep on start-up
    By KIRCHNER in forum Technical Discussion
    Last Post: 01-23-2019, 10:56 PM
  2. Replies: 11
    Last Post: 06-25-2017, 12:04 PM
  3. OPtimax 4 beep alarm
    By luckycraft in forum Technical Discussion
    Last Post: 05-28-2009, 10:05 AM
  4. Promax 300 alarm beep after overheating
    By 86 apache 22 in forum Technical Discussion
    Last Post: 07-27-2006, 07:08 AM
  5. BEEP BEEP BEEP Water/Fuel Seperator
    By HighVelocity in forum Technical Discussion
    Last Post: 07-12-2006, 07:43 AM
