Results 1 to 11 of 11
Thread: Promax Temp
04-20-2019, 09:07 PM #15000 RPM
- Mar 2018
- NJ
- 196
- 10
Promax Temp
A few weeks i traded power heads with a gentleman in fla. and now have a 2000 225 Promax. (rick-great guy). I am looking to do some kind of temperature monitoring,is it better to use the block top port with a sensor or go to the heads. Thank you
04-21-2019, 04:51 AM #2
There is a port (1/8) pipe thread on the exhaust diver between the voltage regular that work well. The warmer (not hot) the better on the steel sleeve motor. They come from Mercury with 143* stats.
04-21-2019, 07:29 PM #35000 RPM
- Mar 2018
- NJ
- 196
- 10
04-22-2019, 04:50 AM #4
You can use any gauge kit Autometer, Livorsi, Mercury etc. Most complete kits come with multiple fitting sizes. The main thing is to use 1/8" pipe for the mounting on the exhaust adapter port.
Below see blue tape covering the port for anyone else that may be wondering.
If you look closely in below picture I use a 90* push lock fitting you can get at your local hydraulic shop. I personally like to use a 90* fitting for safely/close routing. You do not need a push lock and can purchase a 90* 1/8" fitting from any local hardware store.
Hope pics help. Sometimes they speak a thousand words.
04-22-2019, 08:42 PM #5
Tony...your motors are always so clean...nice
tux974 thanked for this post
04-23-2019, 08:03 AM #6
u wanting to monitor temp or water psi?
04-23-2019, 08:07 AM #7Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Need to do both....
texasvector, tux974 liked this post
04-23-2019, 08:17 AM #85000 RPM
- Mar 2018
- NJ
- 196
- 10
04-24-2019, 04:39 AM #9
Sorry to not have mentioned the temp above but I thought we spoke on the phone, maybe someone else.
Posts above are correct, like to do both!
As for obtaining temp reading you should have a 3 wires sensor on the post head 2 tan/black and 1 solid tan, the solid tan is your temp reading to a gauge. Incase someone was curious the tan/black go to ECU so it adjust fuel mixture.
Temp work on ohms so in order to get an accurate reading the gauge needs to correspond with sender. Teleflex makes the Mercury gauge so they will work or you can get Livorsi or Autometer just MAY have a slight temp variation.
If you use a wet sender it will read approx 25* cooler then block temp its ok as long as you are aware of it.
When I decide to run a wet sender I usually run it from top of starboard head behind stat housing. Just need to use a short sender to not interfear with stat function.
Another bit of info, if you are running stock stats once the tail tale is working/dumping the water temp should be around 140ish.
PS; You want to run a steel sleeve motor nice and warm NOT hot!
W2F a V-King liked this post
04-24-2019, 07:31 AM #105000 RPM
- Mar 2018
- NJ
- 196
- 10
04-24-2019, 08:24 AM #11
Yes, water pressure.
texasvector liked this post
Operating temp for a 250 Pro xb/300 promax
By BKlingel418 in forum Technical DiscussionReplies: 1Last Post: 05-21-2015, 08:02 AM -
Mercury Tech: '96 225 ProMax Temp/PSI ????
By astro@ptd.net in forum Technical DiscussionReplies: 5Last Post: 04-04-2010, 09:33 PM -
Promax temp
By chad202 in forum Technical DiscussionReplies: 3Last Post: 05-19-2005, 02:31 PM -
promax temp ?
By Wan2BFast in forum Technical DiscussionReplies: 1Last Post: 02-20-2005, 01:10 AM -
temp. promax 225 2000
By FlatsMaster in forum Technical DiscussionReplies: 2Last Post: 05-14-2004, 08:51 PM
