Results 1 to 15 of 17
04-19-2019, 05:11 PM #1Member
- Mar 2017
- Cordova il
- 90
Max RPM / timing for stock 92 200hp merc
Hey all love these forums
got a quick question what RPM is safe for my merc as long as I ensure fuel and ignition stay strong
i will be installing velocity stacks and tuned exhaust here shortly
04-19-2019, 06:30 PM #2
Well 1st of all, u need rejet using stacks, and make sure black boxes off and throwed away and timin set 23*, make sure u do ur homework b4 starting mods , if never done it can quickly ruin a good motor, 6000-6200 and will last
04-19-2019, 10:41 PM #36000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Will definitely need to know some number to see if your plastic or steel bearings.
04-20-2019, 01:12 AM #4Member
- Mar 2017
- Cordova il
- 90
OD115252
is the serial number
04-20-2019, 01:43 PM #5
Looks to be steel cage , not 100 percent but from looks of parts diagram , 1 mod needs another mod ,needs another mod , for the motor to run like suppose to and not lean it out.
04-24-2019, 11:47 AM #6Member
- Mar 2017
- Cordova il
- 90
Any idea of how many jet sizes I should increase as a starting point with stacks and the tuned exhaust
04-24-2019, 07:02 PM #7
Well 1st thing , I can't believe race man hadn't said anything bout ur "tuned" exhaust , what exactly did u do to tuner ?? Usually show absolutely no increase in power , plain ole 2.4 bell tuna or a Bob's 2.5 tuner is ur best bet , but tuner requires no jetting but removing air box for stacks , I'd go up least 2 sizes and do throttle chop. What's the compression?
KIRCHNER liked this post
04-24-2019, 07:12 PM #8Member
- Mar 2017
- Cordova il
- 90
It is stock compression for a 92 200hp. the exhaust and stacks are from bobs
04-25-2019, 02:31 PM #9
Ya 2 sizes up should b fine. wont notice nething from tuna ,wont notice anything from stacks , but since it is takin in more air need more fuel, stock fishin mota kinda fat start with and sum dont even rejet ,but jets get expensive. start 2 up , more end up with 1 size up
MercRoy thanked for this post
04-25-2019, 03:08 PM #10Member
- Mar 2017
- Cordova il
- 90
Awesome thanks for the input appreciate everyone time
05-14-2019, 05:27 PM #11Member
- Mar 2017
- Cordova il
- 90
Getting ready to set timing on this engine. Many forums on this site say to remove low/high spark advance permanently and set wot timing at 25 degrees
good advice? And do I remove the idle stabilizer box as well?
05-14-2019, 09:28 PM #12
Yes, remove all boxes except switchboxes. Without indexing flywheel on all six cylinders so you can check each cylinder and set highest running cylinder to 25, I wouldn’t go above 23. To index it, you’ll need a dial indicator set up through spark plug hole, or order the JSRE TDC gauge ( for the money and ease of having what you need, it’s hard to beat). We have a thread on here explaining how to do it.
05-15-2019, 04:02 AM #13Member
- Mar 2017
- Cordova il
- 90
Thank you for the response
i will index flywheel first
05-15-2019, 05:29 AM #14
what boat?... makes all tha difference in what ta do and what ta expect....
05-15-2019, 06:03 AM #15Member
- Mar 2017
- Cordova il
- 90
21 foot checkmate 12 in jack plate and turning a 24 fury
Mercury Tech: Timing a stock Merc
By fairview in forum Technical DiscussionReplies: 2Last Post: 01-04-2009, 05:26 PM -
stock merc. 2.4 200hp questions....
By Fasttoys in forum Technical DiscussionReplies: 11Last Post: 05-03-2007, 10:11 AM
