Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
    Feb 2016
    Nags Head NC
    Sea Foam is wonderful stuff!
    Ive got an 89 Merc 2.5 I winterized with sea foam last October. I went to start it yesterday and on the first try after 3 seconds cranking it fired right up! The way I did mine was with sea foam in a squirt gun and mixed heavy in the gas. I shot a few squirts down each carb while running and shut it off, then a few shots down each plug hole. It works well as a rust inhibitor on tools too. Living right next to the ocean thats an ongoing struggle.
  2. Likes bill mason, Slimm, Will hedrick liked this post
    I’ve been hearing a lot of similar experiences about Sea Foam but I never used it. I don’t think I know much about it, though. I’d be interested in the experiences of others as well. I’ve read many times that people use Sea Foam in their car engines as well, which is something that seems like it could cause issues with engine sensors.
  4. Likes bill mason liked this post
  5. #3
    7 Post(s)
    I use it all the time.
    Greg, it will clear a clogged injector in a car!
    I use it way stronger than recommended too.
    Whrn I buy a car, O/B etc, I dump a whole can in it.
    It wats carbon off of 2 stroke piston rings too.
    Use iron the spray can as James described, but try to flood it out/stall it.
    Let it sit over night then fire it in the morning and watch what comes out the exhaust.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  6. Likes Slimm, Will hedrick liked this post
  7. #4
    Jul 2005
    panama city,fl
    I use sea foam in everything from my lawn mower to my outboard. It works! I compare it to quicksilver or mercury quickleen.
    Jul 2009
    gatineau qc, canada
    can you run seafoam in a dfi motor? i know fogging oil isnt recomended..
    1998 charger stv. 225 promax. -sold-
    1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
    Sep 2010
    nj
    Local to me was a 3.5 hp 2016 4 stroke outboard I wanted to pick up for my sailboat, guy wanted 200 bucks and said the carbs needed to be cleaned due to lack of use. I read all about the Sea Foam and was going to try it, curious myself. I ended up passing since these tiny outboards are cheap to buy new.
    Love sea foam used it for 20 years !!!!
    Jay
    Jay @ JSRE
    Nov 2010
    Dubuque iowa
    I usually have 1/2 dozen cans on hand ,use it it
    in everything!! Great stuff
    The only negative to it is the high alcohol content but it sure is a great system cleaner. I always have it in stock.
  13. Likes Slimm liked this post
    Oct 2005
    savannah,ga
    I use it in all motors.
    Great results.
  15. Likes Slimm liked this post
  16. #11
    Oct 2006
    Hardeeville, SC
    As a proffessional technician I've used Seafoam for decades. It's repaired many running issues in both 2 and 4 cycle engines without having to disassemble anything. I also use it as a preventative in all my current vehicles.
  17. Thanks JBS thanked for this post
    Likes Instigator liked this post
  18. #12
    Feb 2017
    Wixom lake michigan
    Had a small shop marine tech tell me about seafoam quite a few years ago, told me to run it in the fuel, get engine up to temp then let it cool completely. When you start it on the muffs in the yard, watch the **** that comes outta the exhaust! It is a great deposit cleaner it seems lol
  19. #13
    minocqua, wis
    Put a can in each vehicle every year ,and a splash in the outboard tank all the time
  20. #14
    Jun 2002
    Winter Haven Fl.
    It and omc engine tuner are the best.
  21. Likes Instigator liked this post
  22. #15
    Like everything else that works sure has jumped on price from what it used to be
    Jay @ JSRE
  23. Likes Slimm, Rigaud, FAST RALLY SPORT liked this post
  1. How To ?! Splitting a foam-filled or foam core boat?
    By home made tunnel in forum General Boating Discussion
    Last Post: 03-20-2019, 09:49 AM
  2. It's wonderful
    By CUDA in forum The Scream And Fly Lounge
    Last Post: 11-10-2018, 03:17 PM
  3. Wraping hi density foam into tight places without using heat and makingthe foam hard
    By tunnels in forum Fiberglass and Composites Discussion
    Last Post: 01-22-2017, 05:54 PM
  4. Great Stuff foam
    By Flashypaint in forum Fiberglass and Composites Discussion
    Last Post: 11-26-2004, 06:50 PM
  5. Is Sea Foam good stuff?
    By imq707s in forum General Boating Discussion
    Last Post: 06-13-2004, 05:54 PM
