Results 1 to 8 of 8
Thread: Electric priming pump
04-18-2019, 02:48 PM #1Member
- Aug 2004
- savannah Ga
- 82
- 15
What do you use to prime an engine instead of the primer bulb?
04-18-2019, 03:18 PM #2Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
I use portable tanks and if I leave the vent closed and the tank so much as sees a reflection of the sun, it pressurizes.
Some use electric fuel pumps. Holley makes a red and a blue that covers all applications of horsepower for outboards.
05-04-2019, 10:09 AM #3
I went to local advance auto and bought a Holley lectric , but that thing dont push chit , GPH is low and I didnt realize when I bought it , it's a cheapie, bout 50$ I guess , I'm on search for a better pump and reg myself , only bad thing I've noticed ,is if pump ever does fail ,low pressure pump on motor wont pull thru pump.
05-04-2019, 09:34 PM #4Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7147
- 3 Post(s)
I use carter P4600HP pumps on all my stuff and I have had a power wire come loose-vst pump pulled fuel through and motor ran.
05-05-2019, 06:37 AM #5
05-05-2019, 07:20 AM #6Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
The carters like this are gerator pumps. Nothing to wear out. Flow -thru design. They work very well, and are extremely reliable. Use 3/8'' fittings only. 3-6 psi and up to 110 gph. The one referenced is 100gph which is plenty of fuel even when drawing thru and pushing thru filters. These pumps push, a lot better than they pull fuel. So mount close to the source and slightly lower if possible.
Rigaud liked this post
05-05-2019, 07:59 AM #7Supporting Member
- Apr 2003
- 6,644
- 606
- 923
- 1698
- 7147
- 3 Post(s)
I run a small inline filter from my tank pick up then the pump is in next in line. After the pump, I push through a water separator then a Fram HPG1, into a slosh tank. The slosh tank has an intake line in the middle, a feed line (to the motor) in the bottom, and a return line to the main tank out the top. The return line has an inline fuel pressure regulator set at 3 psi that forces the slosh tank to stay full and preload the VST at 3 psi. Every outboard that I have (aside from a 50 yamaha) is rigged like this.
This might be a little over kill but over the years I have learned two things.
1. Keep fuel in the motor and it will live-
2. Keep water in the motor and it will live-
XstreamVking liked this post
05-05-2019, 09:34 AM #8
The whole concept of using the Carter pump is that it is a "lifting" pump that provides high volume @ a low pressure. Perfect for boats that have a pick-up tube mounted at the top of the tank. I believe the little Carters can lift 24" and still maintain their rated output numbers. And do not need to be regulated before going into a VST.
Squeeze ball , filter , pulse pump , filter , VST ( needle+ seat ) , screen , Walbro hi-pres pump all seemed compact , but with a lot of restrictions.
I Used a (big fitting) Mercruiser filter , Carter 4600 lift pump , to a stringer mounted sump box / Bosch 044 , fuel rail to a little Aeromotive regulator back to the box , and the overflow into one of the filter inlets . No air bubbles make it down and around the corner to run thru the pump and depending on injectors. It could run 30 to 90 lbs and never make a peep ..
stoker2001 liked this post
3.0l optimax oil pump priming
By harrells in forum Technical DiscussionReplies: 6Last Post: 11-18-2012, 10:18 AM -
Installing Electric fuel pump on Looper, do I need to remove the VRO Pump?
By imq707s in forum Technical DiscussionReplies: 6Last Post: 05-12-2005, 02:21 PM -
electric fuel pump, through factory pump, or by pass?
By WATERWINGS in forum Technical DiscussionReplies: 6Last Post: 06-02-2003, 11:38 AM -
Priming pump on Yamaha
By Markus in forum Technical DiscussionReplies: 5Last Post: 04-17-2002, 08:34 AM -
Electric Fuel pump-vs- stock pump
By B.Mac in forum Technical DiscussionReplies: 29Last Post: 10-11-2001, 03:49 PM
