Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
    Mar 2019
    USA
    Does anyone know what connects here under the carbs on the starboard side? Is there where the thermal valve connect to?
  2. #17
    Rhode Island
    WOAH! Those flying things on the jetski!! scary haha. I've seen some guys try it up here and totally eat it.
    Does it disconnect quickly? Like can you take it off, go to a destination, reattach and play?
  3. #18
    Sep 2017
    Ashland city tn
    Looks like oil return for oil injection, when deleted those usually get plugged.
  4. #19
    Mar 2019
    USA
    I got the boat in the water!!
    Recap:
    Hull Trailer and Bracket (included hydraulic helm and gauges and leaning post) : $500
    Outboard (1992 Mercury 2.5 200) : $500
    Misc (Hydraulic hoses, fluid, impeller, thermostat, prop, hub) : $500
    Motor Install with Jackplate : $320
    New Hydraulic Steering Ram : 438
    New Battery: $80
    Binnacle (bought a 115hp Merc with Binnacle Key-switch and Cable for $600 and sold it for $850 without the controls) : -$250
    Total : $2,088 to splash her. Going to remove the eagle decal and detail her.
  5. Likes 89LASER, Whaaaaat, RUM RUNNER 305 liked this post
  6. #20
    Sep 2011
    maryland
    Quote Originally Posted by jsboat View Post
    Thanks, I'm going to block it off and just run straight to the pisser. What can I say I am addicted to cheap boats builds. The boat looks 14' in photos because of the bracket. Guy I bought it from said it was a drug boat in its past life. Someone went through great lengths to close the transom, reinforce it, then cover the bow with fiberglass. Going by Chapparals site this was a side console bowrider. I am going with a 4 blade $100 quicksliver nemesis propeller 14 x 19 that came in today. I'll be happy if this thing hits 50mph.
    (Boat)Original 198xl maybe? You should see at least mid 50's very easily............with the right prop. Wouldn't surprise me if you saw close to 60.
  7. #21
    Its the pressure fitting to pressurize the oil tank in the boat. It needs to be removed and a pipe plug put in place.
  8. #22
    Rhode Island
    OR a short 1" long hose, and a bolt in the other end haha.
  1. Replies: 0
    Last Post: 01-25-2016, 10:11 AM
  2. 21' Robalo center console 200 2.5 mercury only getting 3000 rpms?
    By camaroguy71 in forum Props, Setup, and Rigging
    Last Post: 01-04-2013, 06:12 PM
  3. 125hp Mercury on a 15' center console Yes or No.
    By Gators27606 in forum General Boating Discussion
    Last Post: 07-15-2012, 10:44 PM
  4. Mercury 2.5L 200hp Build Up
    By chubsta in forum Technical Discussion
    Last Post: 08-08-2002, 08:15 AM
