Results 1 to 6 of 6
    Nov 2018
    Lafourche La
    2002 JSRE 225X Pro Max $6500
    This is one of the cleanest 225X’s that exist. 15Hours on Fresh JSRE rebuild. Motor is impeccably clean. Not a scratch. $7000 in receipts from Jay Smith. Sports master Lower with Fat Shaft. Just serviced lower. Titus Skeg mod. 60 amp charging system. Motorola ignition system. Runs perfect and Looks Perfect. Call or text 504-281-3670. Priced at $6500. Can be delivered within reasonable distance.Click image for larger version.
ID:	436469Click image for larger version.
ID:	436470Click image for larger version.
ID:	436471Click image for larger version.
  2. Likes whipper liked this post
    Mar 2015
    Oregon
    how many hours before the rebuild ?
    any modifications from factory specs ?
    Jul 2004
    Connecticut
    Quote Originally Posted by BayouRocket View Post
    This is one of the cleanest 2002 225X’s that exist. 15 Hours on Fresh JSRE rebuild. Motor is impeccably clean. Not a scratch. $7000 in receipts from Jay Smith. Sportmaster Lower with Fat Shaft. Just serviced lower. Titus Skeg mod. 60 amp charging system. Motorola ignition system. Runs perfect and Looks Perfect. Call or text 504-281-3670. Priced at $6,500. Can be delivered within reasonable distance.
    What was done to the ignition system and the skeg?
    Attached Thumbnails Attached Thumbnails 0719F926-1EA0-4527-8CFD-D4A2D917C5FF.jpg
    Nov 2018
    Lafourche La
    hours.
    Hours were 180 when a injector failed and burnt a cylinder.
    Nov 2018
    Lafourche La
    Skeg
    The Titus Skeg mod helps with steering torque. I noted the Motorola ignition system because it differs from the standard promax. The Motorola system is far better than the older style.
    Nov 2018
    Lafourche La
    Motor is Sold. Thanks,
  1. 2002 Mercury 225x
    By Merc106 in forum Outboard Engines
    Last Post: 12-23-2018, 02:22 PM
  2. 2002 Pro Max 225X with Fresh Rebuild- $6500 Firm
    By gaf11 in forum Outboard Engines
    Last Post: 12-08-2018, 06:40 PM
  3. 2002 225x for sale
    By stalk360 in forum Outboard Engines
    Last Post: 06-22-2016, 09:55 AM
  4. JSRE 225X O-Ring Head Cut Service
    By David L in forum Technical Discussion
    Last Post: 12-15-2011, 08:10 AM
  5. 2002 225x Question
    By Daddio in forum Technical Discussion
    Last Post: 12-25-2006, 06:20 PM
