Results 1 to 4 of 4
Thread: EFI to Carbs
04-16-2019, 08:06 PM #15000 RPM
- Mar 2002
- SW FLA
- 162
EFI to Carbs
On a 98 2.5 200 efi to switch to carbs will the harness on the engine work to switch over to carbs I know the engine harness doesn't have the black and yellow enrichment wire but can be tapped into from the boat harness
04-17-2019, 07:57 AM #2
The yellow/black wire is in there it’s just taped up by the main harness plug. And yes that harness will work for carbs.
04-17-2019, 08:09 AM #35000 RPM
- Mar 2002
- SW FLA
- 162
Good deal thanks I guess u just leave the efi harness off to the side
04-17-2019, 08:39 AM #4
No problem. I cut it out where it connects into the switch box harness and just solder and heat shrink the wires back together.
OMC Tech: Older 75hp evinrude carbs vs 86' 70hp johnson carbs
By roycesrolls in forum Technical DiscussionReplies: 2Last Post: 06-01-2012, 08:24 PM -
OMC Tech: 1989 looper 140 carbs-swap to 94-up carbs?
By gregr1971 in forum Technical DiscussionReplies: 3Last Post: 04-10-2012, 01:16 PM
