Results 31 to 45 of 53
07-06-2019, 10:52 AM #315000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
07-10-2019, 05:43 PM #325000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Got my bleed lines all set. Still don't understand why 2 goes to 6 and 3 goes to 5 instead of 2 to 5 nd 3 to 6, but that's how the diagram shows it so that's the way it goes.
Now ready to wire up my power trim. The motor originally came with a 3-wire system, but after messing that up (not entirely my fault) I replaced it with a 2-wire system.
Instead of the two relays and such, anyone know what parts I need to replace that for the 2-wire system? Must be some sort of different connections.
07-10-2019, 05:54 PM #335000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
I guess the 3-wire has selonoids and I have to replace them with relays.
07-12-2019, 12:29 AM #34
Glastron1987 thanked for this postGlastron1987 liked this post
07-16-2019, 07:11 PM #355000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Anyone have a photo from the back of the engine showing how the 2-wire relays mount to the plate between the coils/heads. Having trouble figuring on which holes to use that keep them and the wires neatly positioned.
07-22-2019, 08:08 PM #36
Hurry up and finish it !!
07-23-2019, 06:27 AM #375000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
07-27-2019, 07:46 PM #38
07-28-2019, 06:38 AM #395000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
The main things left now are stator, switch boxes, flywheel, and lower unit before I fire it up and mount it. I am quite hopeful for a voyage before winter. Away for a few days. But getting excited. Have nearly all the parts to finish except the stator. Want yo go new on that but boy are they expensive.
08-05-2019, 07:41 AM #405000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
08-05-2019, 08:33 AM #41
That hose would go to your remote oil tank to pressure it up to fill tank located on motor. Will not be used if oil injection is deleted. Best to remove check valve and plug like other motor if not using oil injection
08-05-2019, 04:06 PM #425000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
08-05-2019, 06:14 PM #43
08-08-2019, 07:10 AM #445000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Here's a photo of all the oil injection parts that are no longer needed after the system has been deleted. This will be how I'll be running my second boat. I do have to add that my first boat has been running with oil injection for 31 years without incident, but deleting it on the second boat sure makes for a less complicated piece of machinery.
08-08-2019, 07:43 AM #455000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Voo Doos Deltas &Airides continued II
By airide18 in forum General Boating DiscussionReplies: 7Last Post: 09-27-2004, 07:11 AM -
S. Jersey continued
By at100plus in forum The Scream And Fly LoungeReplies: 8Last Post: 12-10-2002, 10:56 PM -
ATV in NJ continued
By at100plus in forum The Scream And Fly LoungeReplies: 5Last Post: 11-21-2002, 10:03 AM -
Prop Talk Continued...........Mach??
By in forum Props, Setup, and RiggingReplies: 5Last Post: 07-19-2001, 06:59 PM
