Results 1 to 3 of 3
04-15-2019, 04:28 PM #1Member
- Nov 2012
- Wis
- 53
Replacement tilt pin for a 25 HP Johnson?
Does anyone know what size replacement pin would fit a 1970 25 HP Johnson? Length and diameter please. Thank you.
04-16-2019, 12:29 PM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
Old OMC part number for the tilt-pin on that motor was #378158. This part number was replaced by OMC part #387524. They can be found as used parts online, researching under either part number, and are available out there. If you don't want to pay the money for one, and you operate on fresh water, you can size the diameter of the clamp bracket tilt pin holes with your drill bit index & get a piece of smooth rod, & thread the ends. don't use threaded rod. and you don't want to do all this if you run in saltwater. if you do, only buy & use an original part.
04-16-2019, 06:19 PM #3Member
- Nov 2012
- Wis
- 53
40 hp Mercury Gas Tilt Assist Ram replacement
By surfdog27 in forum Technical DiscussionReplies: 0Last Post: 03-14-2017, 06:26 AM -
OMC Tech: Tilt/Trim motor replacement.
By RevmanII in forum Technical DiscussionReplies: 5Last Post: 07-28-2011, 03:03 PM -
Tilt n tilt wiring 1977 johnson 140hp ?
By phillnjack in forum Technical DiscussionReplies: 6Last Post: 02-28-2011, 01:47 PM -
OMC Tech: How To: OMC Tilt Tube Bushing Replacement (w/ pics)
By imq707s in forum Technical DiscussionReplies: 20Last Post: 10-23-2009, 01:31 PM
