Results 1 to 13 of 13
    Aug 2017
    Brazil
    102mph - Veloster 400R Accident
    Sometimes distractions could get very expensive...
    https://youtu.be/2eeyG2WUS5Y
  2. Thanks aggiestckl thanked for this post
    minocqua, wis
    Them some lucky dudes
    Push your luck and sooner or later it will run out... We all have pushed it, I guarantee it.....He and his bud were real lucky...Reaper lost out this time....
    Aug 2017
    Brazil
    I agree... that's why i said on video, that GOD took care of us... it's a really scare situation, and i really don't want to go thru this again..
    Jun 2004
    Morgan City, LA
    Quote Originally Posted by wwwalter View Post
    Wow! You both very lucky...
    2012-2013 DSRA PRO STOCK HIGH POINTS.
    2013 DSRA SUPER STOCK HIGH POINTS.
    2014 DSRA SUPER COMP HIGH PONTS.
    2015 DSRA SUPER COMP HIGH POINTS.
    2014,15,16 ODBA SUPER STOCK WORLD CHAMP.
    2016 ODBA SUPER STOCK HIGH PIONTS.
    Jun 2018
    Floating around
    Wow that happened so fast. How do you avoid blowout? I've had paddle wheeling pretty bad and that was super freaky
    1988 Hydrostream Valero V, 2.0L Mariner
    1985 Beretta, Evinrude 115 crossflow
    Juneau, WI
    Four-strokes are soooo dangerous!
  9. Likes powerabout liked this post
    Aug 2017
    Brazil
    You can recover the boat track after a prop blowout with instant slightly and precise corrections, donít releasing the foot from gas pedal, etc... this is the theory part, lol...
    Jun 2018
    Floating around
    During blowout my understanding is the prop loses bite and the hull drops into the drink which unsettles the tea kettle because of the high speeds involved. Is that accurate?
    If so the solve is to restore prop bite which the only way/s I can think of are to shake the wheel a bit and trim down perhaps? I have limited jack plate experience but mine moves fairly slow so I can't see dropping engine height as any effective solution but a little trim down wheel wiggle action would be quick and easy to do so is this wise or whats the playbook here? I want to visualize the best methods repeatedly before I get my speed up higher.
    thanks
    Jul 2005
    panama city,fl
    Lake Fever, I bet there is no time to do anything about it, looks like it happens fast! I don't understand why a lab finished et would loose bite on that flat calm water either. I run my Action fast with a merc et prop and have never even thought about blow out. Now I cant get it off my mind, but at 90 to 100 mph I bet there is nothing we can do if it happens. I just would like to know how to prevent it from happening in the first place!
    Jun 2018
    Floating around
    That makes two of us. I was pushing my set up over the limit many times during test runs and it was paddle wheeling and dropping down into the drink quite a bit pending engine height and trim. My set up is slow I dont think it will crest 60mph as it sits and most of the negative effects seemed to happen around 50mph. Once I got the hang of it I found an engine height that seems to work, and barely any trim and its all good now. I am years away from pushing for high speeds but I sure would like to know the warning signs or experiences from others who may be able to offer some insight.
    "Speed doesnt exist until you crash" Jackie Stewart
  14. #12
    Jul 2005
    panama city,fl
    At the 2;22 mark in video he states this has happened more than 20 times! That's crazy to keep pushing a ill handling boat that fast when you know it will blow out on you! I guess he learned the hard way that his boat has a handling issue!
  15. #13
    Apr 2014
    nj
    Don't forget about the massive weight and combined high CG that comes along with that setup def amplified the problem and or was the problem , maybe too fat gearcase combined with steering inputs led to blowout then the high CG rolled the boat ?
  1. Mercury 400R
    By skydog in forum General Boating Discussion
    Last Post: 07-11-2018, 07:04 PM
  2. Max 5's on 400r's
    By bsboss in forum General Boating Discussion
    Last Post: 06-05-2018, 08:30 AM
  3. 400R vs. 400R Carbon Edition
    By whytey in forum General Boating Discussion
    Last Post: 01-23-2018, 02:45 PM
  4. 400r
    By NeedOne in forum Photos and Videos
    Last Post: 12-10-2017, 08:04 PM
Diamond Marine
