Results 121 to 135 of 136
Thread: Another vertex ring issue
05-09-2019, 03:11 AM #121Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
chaz..... can you cut a crank to make it lighter? Just my 3.4 project......planted seeds but no results....
05-09-2019, 09:03 AM #122
No sir, they case harden the whole thing.
I'd be nice to be able to turn the rod journals on a scuffed one and send it again, but
I have found some bit's that will break thru the "skin" on the counter, so they can be balanced though ...
And bought a bob-weight set and made up a small diameter pin / light parts kit for it
05-09-2019, 10:02 PM #123Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
That's what I was thinking..... too hard.......so 50 lbs of rotating......no need for flywheel.....other than ring gear.
05-10-2019, 08:20 AM #124
The majority of the weight is close to the centerline and fairly streamlined. The only two places there is any "excess material" is in the the counters at each end. If you got rid of them, you would have to put it back with slugs closer to the center.
Six of one ...
Normal balance (3.0L) takes bout 20g off the bottom weight. You can either drill it or do a little semi knife edge with a flapper wheel.
05-10-2019, 10:06 AM #125Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I was thinking taking off lbs.......on each round thing that holds the rings .....that seps each cly....On the side out of the crank case area. Taking off more metal close to the crank pin to lessen the need for the big counter weights at each end of the crank.
05-10-2019, 01:57 PM #126
Well, bear in mind that this thread started about how one brand of pistons and rings were different than a different brand of pistons and rings that are different. Which is not surprising since they are different. I.e. they are not the same.
So, I think we actually made it better.
05-10-2019, 11:20 PM #127Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
So whats your favorite ring package
2 rectangular 040 thick?
05-14-2019, 08:21 AM #128Markus' Performance Boating Links:
05-14-2019, 07:33 PM #129
think everybody's rings ok ,start new thread who likes boobies lol
05-14-2019, 07:46 PM #130Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
keystone rings best.... than L shaped.... Quincy looper rings....end......Kstone.... self cleaning......omc and force rings at 90 # cut are fragle......JMO....I like the newer OME merc rings stout......
05-14-2019, 10:46 PM #1316000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Eli, boobies are ok but to big and things start knocking when they shouldn’t, so keep um flat and you’ll stay safe. Now dished is just for blowers.
05-15-2019, 08:45 AM #132
Best of both worlds "Monster Energy Cup"
.028 x .140 He11fire top
.032 Napier second
2 mm 10 lb oil ring
Unless they came out with something better in the last couple weeks since Talladega ...
Dave ... need pit-cher of 3.4 crank to get back on - off topic ...
05-15-2019, 07:12 PM #133Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
oil rings, thats whats missing from my engine!
05-15-2019, 07:54 PM #134
Dave Strong liked this post
05-15-2019, 08:13 PM #135Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
vertex 1.5mm ring part #
By texasvector in forum Technical DiscussionReplies: 5Last Post: 01-09-2019, 09:38 PM -
Mercury Tech: Dual temp gauges issue OR engine Issue
By dompie99 in forum Technical DiscussionReplies: 4Last Post: 05-24-2016, 09:37 AM -
250xs top cowl melting common issue or is there an internal issue I should look for
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 08-30-2015, 05:14 PM
