Results 1 to 11 of 11
Thread: Which carbs on inline six
04-10-2019, 10:16 AM #15000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
Quick question for the inline gurus, I have a 1971 115 Mercury short shaft on a little MX-14 Checkmate, I also have a 1971 135 Merc and a ? 150 Merc with distributor, for best power and performance, which would be the best carbs to use on the 115???? Thanks, Mark
99fxst99 liked this post
04-10-2019, 10:26 AM #2Member
- Dec 2004
- Ocean Springs, MS
- 78
I think they're gonna tell you that depending on the horsepower, different in-line 6 motors not only have different carbs but different port timing inside the motor.
04-10-2019, 12:01 PM #3
04-10-2019, 02:28 PM #4Member
- Dec 2004
- Ocean Springs, MS
- 78
04-10-2019, 02:55 PM #5
I think the carbs were the difference between a 71 115 and 135
04-10-2019, 06:48 PM #6Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
and reed opens.......stops. carbs had bigger venturies inserts.... less flow.
04-10-2019, 08:47 PM #75000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
I thought the reed stops were twice as big on the 135, something like 5/16 versus 5/32??? Are you saying the 115 carbs have less flow??
04-11-2019, 08:59 AM #8Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I belive so...... many years ago. Think 115 had big blobs of plastic to cut the area. Early 115 and 135 blocks were the same....
04-11-2019, 11:23 AM #9
They use different carbs. Not sure if venturi size is different but they are different part #'s
08-17-2019, 09:43 AM #10Member
- Oct 2007
- 88
- 10
- 31
- 48
just swapping the carbs on the 115 is going to be more problems than it is worth. The only difference between the 115 and the 135 are the carbs and reed stops. The 115 is a choked down 135. There are no other differences. The 150 is a totally different animal. Here are a couple of pictures of the carb throats to see the difference, the 115 has the venture restrictor in it and is also jetted quite a bit smaller. 1350 carb on the left.
1964 Chris Craft Holiday
Homemade Glen-l Crackerbox
71 Switzer 17 with twin Merc 1350s
08-19-2019, 05:45 AM #11
The 115 reed cages have less ports in them than the 135 140 motors, along with the carb differences. No, it's just not worth the trouble to switch the carbs out. You're much better off switching to the 135 140 powerhead. The 150 won't fit the early midsection. Just my thoughts, here
inline 4 diffrences between 85xs and regular inline 4 motors
By evinrudejohnson in forum Technical DiscussionReplies: 3Last Post: 05-27-2014, 01:45 PM -
115hp inline carb and 100hp inline motor
By coreyh912 in forum Technical DiscussionReplies: 2Last Post: 02-19-2012, 10:48 AM -
Mercury Tech: Mercury 90hp inline 6, carbs rebuilt - still no power under load
By milner351 in forum Technical DiscussionReplies: 18Last Post: 08-03-2010, 02:09 PM -
Another Inline Question (Carbs)
By mragu in forum Technical DiscussionReplies: 1Last Post: 12-28-2009, 08:59 AM -
inline 6 carb??? 150 carbs to 115
By Six Four in forum Technical DiscussionReplies: 7Last Post: 06-13-2005, 08:51 AM
