Results 1 to 5 of 5
    Mar 2019
    Houston, TX
    Eliminator 21 Daytona
    For Sale 10 K OBO
    21 Daytona 1980 Hull
    1988 Evinrude OMC V8 300 hp
    1992 Trailer
    (325) 665 Nine One Two Two
    Everything is located in Houston, TX.
    I bought the boat out of Arkansas in July 2017. Boat needed some things fixed as it had sat for a few years and the guy didn't know what he was doing. The SeasStar steering was on backwards, the center pod did not have a bilge pump, the trim was 3 way constant on-off-on switch below the gear shift among other things. So I had all of those things fixed. Also had a blow out on the way home from Arkansas, which pulled the fencer between the tires and caused the boat to hop. It bent the rub rail in the front (I hated how it was done but had to get it home to fix it and just didn't make it) so some of the pictures show tape in place to hold it. That has been riveted back correctly as you will see in some of the other pictures. So it has all new diamond plate fenders and a new front tie down which you can see in the pictures. The boat ran great the rest of 2017 and all of 2018. We had it at the San Jacinto River below lake Houston almost every other weekend, as well as Possium Kingdom and Texhoma in north Texas and Lake Travis in central Texas. Boat and motor never gave me a problem once! That was big to me because of my 3 year old and pregnant wife did not need to be stranded on the lake somewhere. The boat is going to need a new interior in the next few years in my opinion and the jell coat needs some work and has a crack in the very center of the raised part on the bow, my guess is that someone much to large stepped there in the past. The belly tanks were removed prior to me purchasing the boat, and it has a 30 gallon tank under the rear bench seat. Motor has perfect compression, and runs like a beast it has cut exhaust but comes with a plate that can be bolted on to force the exhaust down. We had # 2 in October and that put me at 2 kiddos under 3. I was looking for a 28 to 32 foot formula most winter but ended up buying a Donzi 28 ZX Scorpion. Sooo I need this one gone! I don't have the space for both boats and probably won't use it this summer with us having a 5 month old and a 3 year old.
    Thanks,
    Chase
    Attached Thumbnails Attached Thumbnails IMG_1030.jpg   IMG_1028.jpg   IMG_1026.jpg   IMG_1023.jpg   IMG_1019.jpg
    Mar 2019
    Houston, TX
ID:	435790Click image for larger version.
ID:	435789Click image for larger version.
ID:	435788Click image for larger version.
ID:	435791Click image for larger version.
ID:	435792Click image for larger version.
ID:	435793Click image for larger version.
ID:	435794Click image for larger version.
    Mar 2019
    Houston, TX
    https://www.facebook.com/groups/3527...32638443594481
    Here is the link to facebook and in the comments of the add there are videos of the motor running as well as the boat running down the lake. Most of the videos are my wife driving!
    Jun 2019
    Tulsa
    Is it sold??
    Nov 2004
    Ft Gibson Lake, Ok
    can you please call or text me 918-264-4358 Jon. I also pm'd you
  1. Eliminator Daytona
    By blowitup in forum Hulls larger than 20'
    Last Post: 07-20-2017, 12:04 PM
  2. 23 Eliminator Daytona
    By blowitup in forum Hulls Wanted
    Last Post: 07-12-2016, 08:43 PM
  3. Eliminator Daytona 25'
    By Rusty3 in forum General Boating Discussion
    Last Post: 02-08-2012, 12:56 PM
  4. 21' Eliminator daytona
    By togi in forum General Boating Discussion
    Last Post: 07-14-2003, 07:34 PM
