Results 1 to 15 of 15
Thread: Cowling Upgrade
    Williamston S.C.
    Cowling Upgrade
    What would be needed to replace a Black Max clamshell cowling with a one piece cowling?
    Thanks , Al
    THE EAGLE FLIES AGAIN
    Gothenburg, Sweden
    Quote Originally Posted by BIG AL View Post
    Thanks , Al
    Top cowling
    Bottom cowling
    Latches
    Stickers
    2 base plate gaskets
    Lifting the powerhead on an old engine will probably be the most difficult part of the exercise. Those studs tend to get corroded.
    You may want to replace the base plate at the same time.
    Jul 2008
    severn bridge
    maybe some tell-tale plumbing,might as well go twin pisser!! god I'm getting old,can't even remember where the pisstale exits on a clamshell and I have 2! oh ya, out the bottom of the clam bracket!
    Williamston S.C.
    Could you use a 2000+ cowling with the 2 piece lower and not have to pull the power head?
    Thanks, Al
    Jul 2005
    Baton Rouge, LA
    The 90s drop on cowls and the alien cowls all mount using a base plate that is sandwiched between the adapter and power head. Doesn't matter which adapter is used for mounting but the base plate needs to match as some don't have a hole cut out for the poppet on a 2 piece adapter.Click image for larger version.
    Thanks, Al
    Yes,..
    Thanks, Al
    Williamston S.C.
    Someone had mentioned that going that rout would be the easiest but I wanted to make sure it was do-able.
    Thanks, Al
    Sep 2017
    Ashland city tn
    Thanks, Al
    This is the style cowl I have , and makes it so much easier to work on and just 2 or 3 min to get it all off.
    Jul 2008
    severn bridge
    aren't those cowls 15lbs!
  11. Likes ssv1761982 liked this post
  12. #11
    May 2002
    Harriman, TN
    You may have to lift the powerhead to get #31 installed. I don't think you can get those nuts off unless you lift it just a little tiny bit.
    Those are heavy cowls.
  13. Likes captblue99 liked this post
  14. #12
    Gothenburg, Sweden
    Thanks, Al
    Yes.
    You can keep the top cowling as well.
  15. #13
    Williamston S.C.
    Thanks to all, now just to find a cowling.
    Al
  16. #14
    Dec 2001
    I have all the stuff ya need........any style but race......
  17. #15
    Sep 2017
    Ashland city tn
    Quote Originally Posted by ssv1761982 View Post
    The 3 piece bucket is actually lighter than newer style bucket , I was gonna trade but mine was lighter so I stuck with it , it was a noticable difference just picking up the bucket , with the (200 xri cowl) being lighter
  1. Upgrade from my D50
    By Sutphil in forum Media Creation - Photo and Video Discussion
    Last Post: 09-16-2013, 07:20 PM
  2. Amp Upgrade
    By head_dunce in forum Electronics, Audio Systems, and Wiring
    Last Post: 03-30-2010, 04:16 PM
  3. Upgrade
    By RLC PE in forum Scream And Fly Team Membership
    Last Post: 09-09-2008, 09:50 PM
  4. Cowling upgrade?
    By yanny_haulinbass in forum Technical Discussion
    Last Post: 09-22-2005, 01:07 PM
