Page 2 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 16 to 30 of 189
Thread: 300R vs 300X
    Jul 2004
    Connecticut
    Even though props stink, I guess it is becoming harder to argue with 87 Octane, 5 years of warranty, and 561 lbs.
  2. Thanks PRE-Z06 thanked for this post
  3. #17
    Aug 2018
    On a racetrack or at the lake
    Quote Originally Posted by JPEROG View Post
    They will never run that much better then an X or an XS without having them propped correctly and the engine height being up to get the bigger case to surface. These new gear cases are .600 bigger in dia. so you need to go at least that much bigger in prop dia. to compensate then they also take advantage of being able to turn a 5 blade for hook up and efficiency on top of that.
    There is no sense in commenting about them unless you have experienced it. Both Randy and I were anti four stroke and never had an appreciation for a 400R in a single application. -I didn't think they were ever going to come out with anything better then an X again "I was wrong".
    These motors are also set up in a totally "de-tuned" form so that they can run on swamp fuel-There should be very little warranty claims in this form. Give it a little time and see what happens when someone puts some compression, cams, and head work into the picture. It will be the ultimate outboard under 550 lbs. and will make the best river rat motor ever.
    Agreed they sound great, are very durable and have potential just wish they didn’t weigh so much, it’s like the new Corvette’s getting heavier unfortunately.
  4. #18
    Sep 2012
    I understand that the new technology is the real deal...but the question that hasn't been answered yet is if you put the same 5k prop on a x or an xs...what is the difference in performance? I realize that the gearcase limits the performance on the r unless you use a specific prop....but if you spend the same amount of money on a prop on the x or the xs....is it close in performance?
  5. Likes powerabout liked this post
  6. #19
    May 2016
    keys
    Quote Originally Posted by Turborr View Post
    Stop asking questions like that. Here just calm down now and have some koolaid.
  7. Likes PRE-Z06, Rigaud liked this post
  8. #20
    Feb 2010
    wisconsin
    If you put a newer 4-5 thousand dollar large cleaver on an X or XS would top speed be similar??? Possibly, but it would have to have the torque to get their first and i would think low and mid-range would suck horribly compared to the new 300r. This is the new platform, even the Verado is now going to be limited with its time.
  9. #21
    Jul 2004
    Connecticut
    I highly doubt you will ever see someone test a 300R with the big CNC prop and then test a 300XS with the exact same prop in a smaller size.
  10. #22
    FLA
    I will try 1 on my Twister next week with 300x . Will have results with Twister with 300R soon after .
    24 Twister
  11. #23
    The X struggles to get to rpm with the big 5 blade. It bites a good bit more then the 4 blade DeWalds that I usually run-
    Jan 2006
    Pompano Beach, FL
    Personally unit the 300r has a 1.62 gear or unless someone has a 300x with a 1.75 you cannot get a fair comparison. I can tell you i spin a large 15” 5 blade Dewald however it is a 30p and 1.62. It will turn 7000rpm and have no trouble spinning it up!
    JMO
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  13. Likes johnmiffco liked this post
  14. #25
    Quote Originally Posted by Double Rigged View Post
    JMO
    We are talking about a merc cnc 5 blade 15.25 34P.
    Jan 2006
    Pompano Beach, FL
    I get that. Motors would need the same gear ratio. Kind of like saying can a 300r turn that prop with a 1.62. I think everyone understands you cannot beat cubic inch but it is really a dumb comparison. Motors power/torque curves are too different. Each requires a different set up. No doubt the motors are nice have potential in the future but in the end HP is HP. Just need to put it to the water! I am looking forward the next step for that engine and that is when things will get interesting. However you need a small fortune to buy them.
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  16. Likes 2jz liked this post
  17. #27
    Jul 2004
    Connecticut
    Quote Originally Posted by Z06man View Post
    What size Merc CNC 5 blade are you planning on using on your 300X?
  18. #28
    Feb 2010
    wisconsin
    gears
    They did just release new gears for the 4 stroke... 1.60
  19. #29
    Aug 2018
    Quote Originally Posted by wicheckmate View Post
    Sweet!
    http://www.mercuryracing.com/new-1-6...r-fourstrokes/
  20. #30
    8 Post(s)
    any design changes to help the propshaft live?
  21. Likes stoker2001 liked this post
  1. New Mercury 300 Pro XS V8 vs 300R V8
    By Skip 7750 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-10-2019, 12:00 PM
  2. 300r
    By Wild Bill in forum General Boating Discussion
    Last Post: 03-29-2019, 10:38 AM
  3. Mercury 300R V8
    By mkalsabah in forum General Boating Discussion
    Last Post: 02-06-2019, 07:28 AM
  4. STV RR/Euro + New 300R
    By Talon 25 in forum General Boating Discussion
    Last Post: 06-16-2018, 09:53 PM
