Results 1 to 15 of 18
Thread: Attn. Yamaha gurus
04-02-2019, 07:10 AM #1
Attn. Yamaha gurus
What is the difference between a 1992 225 and a 225 Excel? I know the Excel is way more powerful but why?
04-02-2019, 03:31 PM #2
I bet chris carson knows this answer
04-02-2019, 04:03 PM #35000 RPM
- Jan 2017
- Albany NY
- 397
- 28
- 20
- 98
- 125
I bet superbender knows the answer as well
04-02-2019, 08:44 PM #4
ECU, Oil Pump, heavier hood, different part number on the head...but basically the same.
Mine ran 93 on my SRV...'08 SRV
Yamaha 3.1 Phase III
04-02-2019, 09:11 PM #5
So porting should be the same?
04-03-2019, 05:17 AM #6
Now I`m told on another web site that the 1992 225`s had compression notches in the exhaust port. This would make since to me on why these motors lack the power that the Excel has. Other than resleeving there`s nothing that can be done about this. I`ve been through it with a 150hp Merc. Ended up resleeving to get rid of them.
04-03-2019, 06:15 AM #7
04-05-2019, 09:26 AM #8
The Excel was earlier than 1990. The 220 Special came out in 1984. I think the 225 Excel came out in 1986 or 87. It was definitely around in 1988.
The Excel had tighter heads than later 225s. (But not as tight heads as the 220 Special).
Over time, Yamaha learned that compression is a risky way to make power since many people don’t know what those numbers on the gas pumps mean. So they found other ways.Markus' Performance Boating Links:
Forkin' Crazy liked this post
04-05-2019, 09:42 AM #9
All 3 versions of the heads are very close. Even the 220's aren't a bunch different. The knock sensor saves the motor from a certain amount of sketchy fuel.
I wouldn't say that yamaha found other ways to make power considering they use the exact same ideas in the 3.1 and 3.3. Raise the ports and add compression...Last edited by DoktorC; 04-05-2019 at 09:45 AM.
'08 SRV
04-05-2019, 09:54 AM #10Markus' Performance Boating Links:
04-05-2019, 09:59 AM #11
04-06-2019, 08:03 AM #126000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Leaded fuel.
And resulting meltdows on regular.
Lot of changes after the led ban
04-09-2019, 04:42 PM #13
I believe you are correct. I talked to Ray Neudecker extensively about these motors. I had found a Special and was planning on buying it. If I remember right, the Excel had a different front half/reeds cages/intakes???
The 220 Special heads being tighter sounds right also. God I wish I had written that stuff down. Ray was one smart man, RIP.
04-09-2019, 05:16 PM #14
You are correct about the excel having the horizontal front (reeds , intake to match). Carbs where different as well but the same size. Even more right about Ray. I saved all my PM's from him thank goodness I just wish I asked him more questions lol. He helped a bunch of us and was genuinely a nice guy.
'08 SRV
04-10-2019, 09:01 AM #15
Ray was great.
The 220 Special had the vertical intake of the 200 hp and below. From what I remember, the 220 Special also had different carburetors. Not Nikkis, as found on the later engines.
The horizontal intake was introduced on the 225 Excel. That was the first step on the journey to make power from other means than compression.Markus' Performance Boating Links:
Yamaha Gurus
By Damyankee in forum Technical DiscussionReplies: 1Last Post: 02-14-2017, 07:05 AM -
Attn: OMC Gurus
By Efishzion in forum Technical DiscussionReplies: 5Last Post: 11-12-2006, 11:43 PM -
Yamaha Gurus -help!!-
By DonChicho in forum Technical DiscussionReplies: 20Last Post: 02-22-2005, 03:25 PM -
Yamaha Gurus-help!!-
By DonChicho in forum Technical DiscussionReplies: 0Last Post: 02-08-2005, 07:53 AM -
ATTN: Mirage Gurus...
By Jason Huber in forum General Boating DiscussionReplies: 3Last Post: 03-28-2004, 07:43 PM
