Results 1 to 3 of 3
Thread: Stv river rocket engine height
04-01-2019, 09:52 PM #1Member
- Apr 2006
- thunder bay ontario, canada
- 35
Where is everyone measuring there engine height from on a stv river rocket, I have heard from bottom of pad, some say the ledge beside the pad, which is 3/4” higher. Just putting engine back on, last year I was 1 1/4 above the bottom of the pad, also no jack plate and bolted to transom,
1996 stv river rocket. 2.5 260hp
04-01-2019, 10:35 PM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,637
- 606
- 918
- 1698
- 7129
- 3 Post(s)
I measure mine from my water pressure gauge... If you look down the inverted vee "from the front of the boat", you should just barely see your water pickup and that is optimal for most STVs. Set it there and watch your water pressure-its going to get you really close and is probably higher then you have been running it.
RBT liked this post
04-03-2019, 08:11 PM #3Junior Member
- Dec 2016
- MS Gulf Coast
- 24
- 9
- 9
Use the small ledge beside the center pad to level the boat (the center pad runs at an angle ) but use the center pad to set engine height. I am at 1-3/8" above with mine , still have good water pressure.
need help setting my engine height and jack plate height
By johnsongt175 in forum Props, Setup, and RiggingReplies: 2Last Post: 05-27-2014, 07:21 AM -
STV River Rocket 20" 260 Mounted on Transom what height??
By moomba in forum Props, Setup, and RiggingReplies: 2Last Post: 08-06-2011, 02:20 PM -
Motor Height for STV River Rocket
By rsjc in forum Props, Setup, and RiggingReplies: 4Last Post: 05-22-2010, 10:56 PM -
HOW to - jack plate height/engine height
By Techno in forum Technical DiscussionReplies: 4Last Post: 08-21-2007, 12:49 PM
