Results 1 to 10 of 10
03-30-2019, 02:15 PM #1Junior Member
- Sep 2015
- Bermuda
- 12
Mercury 200hp race - starting issue
So I’m caught in a pickle right now scratching my head..
i have a 200hp Merc 2.4 which I have issue with starting. Recently, I had got the timing readjusted and it was turning fine but the battery had died out before I could test the spark to each cylinder.
Bought a new battery and even swapped out the old battery cables on the motor, as he connections were coroded and frayed (still was able to kick over w/ old cables).
Randomly when hen I hit the key it now makes this “click” noise which I figured was the solenoid so I replaced it with a new one but to no avail it’s still making that noise. I’m guessing it’s a bad ground connection somewhere because power is constant through all other functions of the boat but if anything else....please HELP LOL.
03-30-2019, 03:41 PM #26000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
are you grounded directly from battery to motor block ?
03-31-2019, 07:13 AM #3
So when u"hit" the key , the starter or starter solenoid just clicks and wont crank? When u push key in that should b choke solenoid clickin
03-31-2019, 10:19 AM #4Junior Member
- Sep 2015
- Bermuda
- 12
03-31-2019, 10:20 AM #5Junior Member
- Sep 2015
- Bermuda
- 12
06-13-2019, 09:04 AM #6Junior Member
- Sep 2015
- Bermuda
- 12
So still having an issue...changed solenoid, took off carbs and rebuilt them, even changed the fuel pump to a new one.
However i keep getting the same result, motor wants to fire (even shoots out flame from the exhaust) however it doesn't stay started or idle. At a standstill at this point because i've exhausted my brain and im really trying to avoid paying someone else to do it (especially at peak boat season).
Any other ideas or suggestions would be greatly appreciated!!!Boats Beers and Boobs
06-13-2019, 01:56 PM #7
flames and not runnin' usually indicates timin' and/or switch box wiring messed up... double check switch box ta coil colors.. trigger ta switch box colors....
06-13-2019, 01:57 PM #8Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
I’d recheck your timing. If it’s shooting fire out of the exhaust the timing could be too far retarded at idle. Check it on all cylinders
Erik Kiser
06-13-2019, 11:37 PM #9
agree with eric 'bout it.. tha "other stuff" I mentioned usually produces a back fire along with a flame...
06-15-2019, 05:07 PM #10
If you had the coils off check that they went back onto the right sides. Definitely timing issue
Peter Thomas
1977 Mercury 850 Starting Issue
By champ201 in forum Technical DiscussionReplies: 0Last Post: 06-03-2018, 03:49 PM -
Mercury Tech: Mercury 2.5 200 Starting Issue
By rankink in forum Technical DiscussionReplies: 4Last Post: 09-03-2017, 08:18 AM -
1991 200 XRi Starting Issue
By orbeamlb in forum Technical DiscussionReplies: 1Last Post: 04-25-2016, 04:17 PM -
Mercury 300X starting issue
By Steveatmhz in forum Technical DiscussionReplies: 2Last Post: 05-05-2015, 10:00 PM -
Mercury Tech: 2.5 260 starting issue
By john4utvols in forum Technical DiscussionReplies: 22Last Post: 08-04-2009, 09:12 PM
