Results 1 to 9 of 9
03-29-2019, 10:33 PM #1Junior Member
- Dec 2018
- SoFlo
- 16
1999 mariner 135 optimax dfi... Rpm studder at 3500rpm
I bought the boat in December and have been using it since but a few weeks ago i got a check engine light that flashed (i have the 4 cluster quicksilver guage) for engine issue. On the way home the motor seemed to have a little bit of a vibration at lower rpm (misfiring cylinder?) and rpm studders at about 3500rpm or so. The weird thing was once above that rpm it ran fine (5500rpm steady). The next weekend the light came on and stayed on so i decided to invest in a techmate pro scanner. After scanning there was an active fault on injector #3 (further testing showed the direct injector was causing the issue). Got all the injectors and fuel rails cleaned, inspected, and flow tested. Injector 3 (direct had a small leak that was fixed with cleaning). Everything was reinstalled in the motor with new plugs, and fuel water separator filters. This was today. After install scan showed no faults but after a test ride the fault on number 3 came back. (Is it possible for an injector to fail even if it clicks on injector test?) Here is a video of the engine to show symptoms at neutral https://drive.google.com/file/d/1j69...w?usp=drivesdk. Im sure i left out details along the way..ask away with questions... Thank you for help.
03-30-2019, 01:46 AM #2Junior Member
- Dec 2018
- SoFlo
- 16
for some reason the link above isnt working so here it is again https://goo.gl/PrrnJG
03-30-2019, 02:29 PM #36000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Never had a leek fixed by cleaning.
O ring and Teflon seals being replaced during cleaning can. So it’s probably wording.
Cleaning cant save all of them. Might have to replace it.
3500 is around when sensor hand off takes place. you can see if their on the low side probably not bad though. It’s also a good spot for week or stiff reeds and air injection to crossover. Normally never concerns
03-30-2019, 05:00 PM #4Junior Member
- Dec 2018
- SoFlo
- 16
here is a video of my injectors before and after they were cleaned... to clarify what i ment by "leaking"
https://www.instagram.com/firstclass...p/BvmZ0bhF27Q/
03-30-2019, 10:29 PM #56000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Nifty, if they started that again would probably go back to acting up. At high rpm it’s not enough to affect rich lean conditions.
Should have idle and such acting funny though.
04-06-2019, 10:40 PM #6Junior Member
- Dec 2018
- SoFlo
- 16
found out the new plugs i put in, even though they are in the service manual, dont run right (Must use ONLY NGK: IZFR5G Spark Plugs, gapped at .032-.033" )(so i put the old plugs back in the motor and was able to get back my full rpms. motor was running almost normal (how it used to) with much less shakeyness. with that said though there was still a moment on the ride where the injector gave a code. i looked it up and ordered a used one... will update on results once i receive the new injector and install it.
thank you for the help
04-12-2019, 05:52 PM #76000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
A dirty injector wont through a code. Only an electrical issue with it. You need an Injector. Make sure you get the proper one for you pressures
04-12-2019, 07:49 PM #8Junior Member
- Dec 2018
- SoFlo
- 16
thanks, matched model number. just got it in today, getting it cleaned and will pop it in later next week or so
04-27-2019, 11:17 PM #9Junior Member
- Dec 2018
- SoFlo
- 16
Thanks for all the help... replaced the injector today and she is running great!
1999 200 optimax or 2004 250 xs optimax?
By vmax80096 in forum Technical DiscussionReplies: 7Last Post: 07-26-2018, 12:34 PM -
1999 XR6 150 or 1999 Optimax 150
By EMC 2870 in forum General Boating DiscussionReplies: 4Last Post: 07-31-2013, 08:39 AM -
1999 150 Optimax
By rkmirage in forum General Boating DiscussionReplies: 9Last Post: 07-01-2013, 09:33 PM -
studder box
By bits&pieces in forum Technical DiscussionReplies: 12Last Post: 09-13-2007, 02:45 AM -
260 missing at 2500 to 3500rpm
By espen in forum Technical DiscussionReplies: 12Last Post: 07-02-2006, 04:29 AM
