Results 61 to 75 of 103
Thread: The END is near
03-31-2019, 09:48 AM #61Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
03-31-2019, 09:51 AM #62Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
03-31-2019, 10:44 AM #63
This thread reminds me of the old death of the incandescent light bulb thread. We see how that all turned out, eh?
03-31-2019, 10:50 AM #64Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I still use an incandescent in the table lamp where I read
03-31-2019, 01:30 PM #65Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,641
- 606
- 920
- 1698
- 7138
- 3 Post(s)
When electric cars go further then people travel in a 15 hour period and can be charged in 2, the cost is the same or less then a conventional car, and there are charge port stations available like gasoline stations are available now then we will all see the switch. For your analogy of the light bulbs-They sold when the cost came down, they use less power, and last longer then incandescents-it was a great step forward. Its basically the same thing but it will take a lot longer for the automotive switch to meet the required market demands then it did for led bulbs which are now a dollar Vs. the twenty that they were when they were introduced.
I have no doubt that future generations will see alternative energy in transportation but its not going to happen overnight and I hope that everyone realizes that electric is not the fix when you look at battery disposal and the coal and or nuke required to produce the juice....
CDave liked this post
03-31-2019, 06:31 PM #66Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
750 hp , about an hour running time, just the beginning.
https://beta.ctvnews.ca/local/vancou...1_4352713.html
CUDA liked this post
03-31-2019, 06:35 PM #67
Forkin' Crazy liked this post
03-31-2019, 06:36 PM #68
I wonder how much an electric semi costs?
03-31-2019, 06:49 PM #69Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Peterbilt has a couple, as well as Daimler are on it.
03-31-2019, 06:54 PM #70
Joe, I'm an electrician. The wave came when municipalities gave tax incentives/rebates for companies that had high lighting costs from metal hallide, old style flourescent, etc, to retrofit to LED, HO T5 flourescent, and CFL. We we're swamped with the work from that. The efficiency change that came along with that was astounding. 42 ckt lighting panels using every ckt at Max allowed capacity we're at minimum cut in half, as well as less load on the HVAC. I did a retrofit on a cardboard box manufacturer where the temp in the plant dropped 15* getting rid of the metal hallide high bays. Even the best innovation sometimes needs a gentle nudge...
I can't dispute what you say, because that's your story, and I'm sure you're sticking to it. Mine and many others experience is quite the opposite. Which brand are you using? Do they warranty these lamps?
The first push to electric should be local route delivery. Planned, defined routes, easy to calculate. As far as long trips, I would bet the average driver close to never drives more than 400 miles from home. They cost too much? I know plenty of people that have two SUV's in the garage that are the daily driver's. At best 18-20 mpg. It's a free country, people are welcome to do as they please, but $100G plus of financed vehicles sounds far more expensive than one EV, one ICE. Just sayin...
03-31-2019, 08:58 PM #71Supporting Member
- Apr 2003
- 6,641
- 606
- 920
- 1698
- 7138
- 3 Post(s)
That makes sense but I am referring to the masses. There are a lot of changes needing to take place before "the masses" will be purchasing E.V. as their main mode of transportation. I just pulled my C.C. statement to check before I typed this but I spent $850.00 in fuel last month (part of that was a 1500 mile trip) but the rest was normal running around FL. That being said, if the range and price improvements come soon enough on the E.V., I will most likely have one as a second or third car.
03-31-2019, 10:04 PM #72Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
They make sense in big cities, in France the local councils/gov cars have been electric for years.
They dont burn coal to make that power
04-02-2019, 08:11 PM #73
04-02-2019, 08:16 PM #74
How many aircraft are hybrid or electric that are in commercial service? How many ocean going vessels? How many trains in the US?
04-02-2019, 08:33 PM #755000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Don't quote me on this, but I want to say that most modern trains, freighters, cruise ships, and the largest of mining equipment, are all hybrid. And the largest excavators are electric only, direct from the grid.
I would think it's all a function of efficiency thru the drive train. At a certain point the size of the driveshaft and gearboxes just doesn't make sense.
powerabout liked this post
