Results 1 to 2 of 2
    Mar 2019
    Murrieta CA
    CMC Powerlift Hydraulic Jack Plates
    Hello,
    i have 2 used CMC power lift hydraulic jack plates. They are from 1996 and I just removed them from my boat carrying a pair of 300x. One jack is 100% operational and the other no longer has a working hydraulic motor. It’s still in great condition, just the motor went out. You’ll see the in photos that it’s missing and has a wooden 2x4 wedged. Long story short I had to make a quick fix to prevent the motor from slipping down halfway through a lake weekend. Little did I realize that if I had just torqued down the bolts, the 2x4 was not needed. It should serve as a perfect manual jack plate unless you can rig up a new hydraulic motor???
    Make me an offer! I’m localed in Southern California. Shipping may be pricey cause they’re about 50 lbs each. And yes I will scrub them clean before selling I just snapped these photos right after I removed them.
    Attached Thumbnails Attached Thumbnails 9A186014-B589-424F-982D-635420A41D6F.jpg   6BEB0F2C-DC04-406C-8B44-BB9C5D06AD91.jpg   E564AFFB-F776-4283-9467-AC7115EF29B8.jpg   E88274C1-4946-45A4-95A7-0A3D7E7015EC.jpg   422EEF11-6372-4A42-8B56-3E72208E18C4.jpg
    3D76DB23-ACED-4010-94E7-8FBFBCB65FA3.jpg   F8B0F686-4651-4514-B35C-7872AEA46637.jpg
    Dec 2017
    Deville, Louisiana
    Do you still have your jack plates?
  1. Hydraulic jack-plates
    By Doug Hicks in forum Technical Discussion
    Last Post: 09-23-2004, 08:28 PM
  2. Hydraulic jack plates?? yes / no
    By fishinslow in forum Props, Setup, and Rigging
    Last Post: 12-13-2003, 11:39 PM
