Results 1 to 10 of 10
    Sep 2006
    Tallahassee Fl
    225 Optimax problem
    I have two 2003 225 Mercury Optimax one of them me gave me an issues this weekend Im hoping you guys can help.
    We spent the weekend at the beach with the boat. on day 1 it ran great 5 hours of running around at various speeds no issues.
    Sunday we were getting ready to go out. Fired up the engines, warmed them up, idled out (about 15 minutes of idling) went to get on plain at about 2500 rpm one engine would go above 2500rpms and a long beep. As soon as you go under 2500 RPMs no issues beep at all and seem to run fine. Smart craft gauges showed check engine light. As soon I went below 2500 the check engine light went out. The other engine ran great they pull from the same tank. Anything else to look at?
    Did a compression test today and it has me scratching my head.... Is there a compression release on these engines? Both engine read crazy numbers.
    Good engine has 3 reading 20 psi nd 3 reading 0 psi
    Bad engine has 3 reading 20 psi and 3 reading 0 psi
    both tests were done with no plugs in and batteries fully charged. Maybe my Mac gauge is taking a dump?
    Flushed the engines today and they seem to run fine in netural and no strange noises.
    2000 Air Nautique
    GPRXP 90++ mph
    21 Skater 300+ hp (SOLD)
    TX21 Warhawk 2.5 EFI (SOLD)
    17 Action Marine 200 EFI (STOLEN)
    Sep 2006
    Tallahassee Fl
    plugs and compression numbers
    2000 Air Nautique
    GPRXP 90++ mph
    Feb 2018
    Md
    I have same engine. Did exactly the same when alternator went.
    Feb 2018
    Md
    It ran high voltage
  5. Thanks lvnspeed thanked for this post
    Sep 2006
    Tallahassee Fl
    Quote Originally Posted by Seapro mike View Post
    It ran high voltage
    I think you might have nailed it.... Reason I say this is when I was flushing it I heard the belt slipping I forgot to mention it and was going to deal with it when I figured out what was wrong. Now that I am thinking about it I remember the voltage was low at one point in the day but later it was normal. I guess it looks like I need an alternator.
    2000 Air Nautique
    GPRXP 90++ mph
    Feb 2014
    Missouri
    Air injectors open when starting to back fill the air side and get pressure up. no need for it if running a buzzer though. Plugs also look normal if running 91 ( the most common alcohol free)
    Did it turn on the limiter or just sound alarm.
    Regulator draw key off .584mA key on 150mA
    it should have a code stored if you know anyone who can read them since the smart didn’t display the code when it went off.
  8. Thanks lvnspeed thanked for this post
    Sep 2006
    Tallahassee Fl
    Yes running 91 octane
    Solid Beeeeeeeeeeeeeeeeeeeeep and 2500 rpms no more
    2000 Air Nautique
    GPRXP 90++ mph
    Sep 2012
    Make sure the onboard oil tank's float is not defective. Jump the wire to eliminate that.
    Sep 2006
    Tallahassee Fl
    Seapro Mike looks like you were correct high voltage from Alternator. Thanks bud
    2000 Air Nautique
    GPRXP 90++ mph
  12. Likes Seapro mike liked this post
    Jun 2001
    Cromwell. NEW ZEALAND
    Faulty shift switch. The engine has a rev limit when in neutral. If the switch is faulty then the ecu doesn't know when its in gear and so limits rpm and sets off the alarm.
    Popey
  1. Mercury Tech: 225 optimax problem
    By Steveprecision in forum Technical Discussion
    Last Post: 05-18-2017, 03:39 PM
  2. problem optimax 200
    By nikos in forum Technical Discussion
    Last Post: 12-30-2011, 10:00 AM
  3. 115 Optimax problem
    By kostas74 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-13-2011, 06:35 PM
  4. Optimax Problem Need Help
    By terrygdsdn in forum Technical Discussion
    Last Post: 02-15-2009, 08:55 AM
  5. OptiMax 75 DDT Problem!
    By Chriss L in forum Technical Discussion
    Last Post: 03-27-2007, 04:30 AM
