Results 1 to 15 of 22
    Mar 2009
    Port Saint Lucie
    Unconventional molds
    So I've used lots of things as molds. Example. Im rigging my boat with a electric fuel pump. Wanted a small box to cover it and just keep it safe. Found something perfect, so I used it as a mold.
    Attached Thumbnails Attached Thumbnails 20190318_130945.jpg   20190318_130935.jpg
  2. Likes TwzteD liked this post
    Mar 2009
    Port Saint Lucie
    Pump will be mounted to a vertical wall with the box over it. With cutouts for hoses.
    Attached Thumbnails Attached Thumbnails 20190320_181351.jpg   20190318_174739.jpg   20190318_174515.jpg   20190318_174437.jpg
  4. Likes davemvegas, TwzteD liked this post
  5. #3
    7 Post(s)
    That’s bad asss!
    I do the same thing.
    Half the trick to working w/glass is getting the MEK to resin ratio right.
    I build small, custom glass pts all the time.
    Keep it up.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    Mar 2009
    Port Saint Lucie
    Oh, im sure you have.
    Mar 2009
    Port Saint Lucie
    What about the mek ratio?
    7 Post(s)
    Up here in Ohio where temperature chgs constantly, that chgs how much catalyst you add.
    I’ll use up to 3% if I’m working in bellow 70* weather but normally between 1% - 2%.
    If you get it wrong, it either sets up before you’re ready or not at all.
    Ive done both.Ruined a bunch of pts, resin and cloth.
    Down there, you’ll be at 2% in spring/fall or for small pts and 1% - 1 1/2% in August.
    Get you a graduated dispensing bottle if you don’t have one.
    Makes it idiot proof.
    BTW, I still get all my glass supplies from Fiberglass Supply Depot on US1 in Ft. Pierce.
    Great people, product and cheap.
    Attached Thumbnails Attached Thumbnails A7C911A4-502F-4C0C-93B4-CDD5C6DAACF0.jpg
  9. Likes TwzteD liked this post
    I've just used the tupperware containers as is. The waterproof snap on/off lids are great. Battery switches and elec buss gangs etc. Mount the stuff thru the bottom of the box into a bulkhead and it's dry.
    Mar 2009
    Port Saint Lucie
    It was a lunchmeat container. But I've seen Tupperware used. And thinking about it, I could have easily used one. As far as ratio of hardner, 1% is standard when making bigger parts. 3% is usually max. For small stuff I don't even measure closely. I only needed 15 min with that part so I kicked it off hot.
    Mar 2009
    Port Saint Lucie
    I've put buckets of resin in the fridge before to extend gel time too.
  13. Likes Instigator liked this post
    Nov 2018
    New Baltimore Michigan
    I thought mixing to “hot” caused the part to be too brittle. A slow kick time can be speeded up by using heat lamps.
  15. Likes Instigator liked this post
  16. #11
    7 Post(s)
    Correct.
    The excess heat it causes will also cause pre-release where the glass pulls away from the mold.
    Ambient trmerature dictates required amount of MEK.
    Quote Originally Posted by Tin Man 2 View Post
    Australia
    hey fellas, I know you know what you mean when you refer to catalyst as MEK, but that makes it rather confusing for any novices reading your posts, when MEK and MEKP are both commonly used in the composites industry and are readily available at most suppliers. If someone were to mix MEK into there polyester or vinylester resin they are going to have a bit of a mess to clean up
  18. Likes Instigator liked this post
  19. #13
    Jun 2018
    Floating around
    I know MEK as methyl ethyl ketone. We use it for some PVC/ABS work here and there
  20. #14
    Mar 2009
    Port Saint Lucie
    That's right. Mek is thinner/cleaner. Mekp is hardner. And by hot I just mean more than 1% not crazy hot.
  21. #15
    Rule of thumb.....2% is max for resin and 3% for gell. This can be increased by 1% in cold weather but the catalyst has to be used up in the hardening process or it remains in the laminate and can be a problem later. So, use it correctly. Blisters/yellowing of the gellcote is one problem, weakened blistered laminate is another.
  1. molds
    By dirtjumper101 in forum Radio Contolled Performance Boats
    Last Post: 03-21-2009, 09:16 AM
  2. New molds for the 1/10 R/C STV
    By Stealth Assassin in forum Radio Contolled Performance Boats
    Last Post: 02-24-2009, 09:00 PM
  3. Looking for Molds
    By RudeFL in forum General Boating Discussion
    Last Post: 06-24-2008, 04:49 PM
  4. Any one know where the HST molds went from LPB?
    By Capt.Insane-o in forum General Boating Discussion
    Last Post: 08-08-2007, 04:08 PM
