Results 1 to 6 of 6
03-25-2019, 06:24 AM #15000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
Merc 4S 150 plugs - Precious metal "dot" Iridium
Merc 4S 150- 2017- 180 hours- plugs are suppose to have a precious metal "dot" on the electrode. If gone - replace plugs. I pulled plugs to apply anti-seize to threads (per manual on salt water applications) Check gap. All 4 - there is no visible dot. I did not Clean electrode with sand paper or anything. Over all appearance nice tan- good condition. Motor running flawless. Is Iridium actually gone? Should it be at 180 hours?
Just checked price- less $5 each. This actually a fairly common plug- automotive in applications. Seems like an obvious - just change them- except #4 is tricky to get to- risk of strip or cross thread.
Suggestion to others- go ahead and have new plugs on hand- put them in-
03-29-2019, 10:05 PM #2
No issues, no problem. I've had vehicles go 160k miles on factory plugs.
1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
04-12-2019, 05:48 PM #36000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
I wouldn't swap them but if they are out spend the $20 and replace them. A 5/8 deep socket and 1" extension makes number 4 very easy to get out. Just make sure and start it with your hand. Also stand in front of the motor and lean over the top if possible.
As a rule of thumb on non performance 4 strokes I do plugs every 3 years when we do the pumps and t-stats. As recommended by merc
Also NGK claims there plugs already have a super special coating that keeps them from siezing..... pick who ever you believe on that.Last edited by RSWORDS; 04-13-2019 at 08:30 PM.
04-13-2019, 08:14 PM #46000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Don’t remember if iridium have the dot. Platinum normally do. Only affects waste spark where the plugs use resistance in the platinum to create a +- plug so strong spark goes to correct cylinder. It would run rough if it needed it.
04-15-2019, 06:26 AM #5
I ran the standard automotive plugs in my 2013 Merc 150 4-stroke. Changed them every 300 hours. Motor had 2,800 hours on it when I sold it.
Aaron
Fountain 38TE, quad 400 Verados
Talon F20 Flats boat, 250XS
04-15-2019, 06:57 AM #6Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Napa can get you the FR iridiums for about 10-11 bucks ea. 1/2 of dealerprice. Same exact plugs
Iridium Plugs
By hydro in forum Technical DiscussionReplies: 7Last Post: 05-31-2010, 08:09 PM -
Mercury Tech: 300X running NGK iridium plugs
By fastcat1 in forum Technical DiscussionReplies: 12Last Post: 09-20-2009, 10:01 PM -
Precious metal spark plugs
By G Rowe in forum Technical DiscussionReplies: 14Last Post: 05-16-2006, 07:57 AM -
NGK Iridium plugs
By Dingie in forum Technical DiscussionReplies: 13Last Post: 11-23-2005, 10:12 PM
