Results 1 to 5 of 5
    Jul 2008
    Canada
    Looking for a custom Setback plate builder
    Ok so I have run into an issue hoping someone could point me in the right direction. I have a 209TE gambler and the transom has an oddball bolt pattern. I bought a Bobs Action jackplate and can't mount it without some sort of adapter. Problem is a 4" setback plate will be too big. Sooo I am trying to find a 2" static setback plate where I can have the mounting hole drilled to match the bolt pattern of the boat. I can't just drill holes in the bobs because where the holes would go the holes would actually be within 1/16" of the edges on the plate.
    I could just U channel the holes if that makes sense but I think that would affect the safety of the hole thing. Apparently gamblers came with a few oddball bolt spacings. This one is a square with 12 3/16” wide pattern.
  2. Thanks Gorilla0178 thanked for this post
    Gravenhurst, Ontario.
    Contact Rowboat.
    He’ll make ya whatever you need......and he’s in Peterborough.
  4. Likes FMP liked this post
  5. #3
    Jul 2008
    Canada
    That would be awesome. Will do thanks
    Mar 2017
    Miami, FL
    Not familiar with the boat. But wouldn't it be easier to close up the original holes, and drill new ones?
    Jul 2008
    Canada
    Yah, that’s what I’m doing, I will drill new holes for the bottom of the plate then for the top ones will use the stock location on the jack plate and fill and drill new holes in the transom. Had a good chat with rowboat and this seems like the easiest option.
  1. Custom aluminum, powder coated setback and manual jack plate - Like new
    By Mike Nass in forum Misc. Parts and Accessories
    Last Post: 04-21-2015, 10:53 AM
  2. Custom Built Adjustable setback
    By mragu in forum Misc. Parts and Accessories
    Last Post: 09-27-2014, 05:42 PM
  3. Custom setback bracket
    By WILDMAN in forum General Boating Discussion
    Last Post: 02-25-2005, 10:39 PM
