Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
    Dec 2018
    greenville, nc
    Interesting. Never thought of that. Are the pigtail wire colors the same in case I ever see one.
    pigtail is on the main harness. here's a pic
    Click on the 2nd pic from the Mercury online catalog. The first number is superceded by the second. Note the word TAN beside the first pn.
    Most all of the new pn on ebay will have the black connector and would not work with my motor.
  2. #17
    So all you did was change the water psi sensor? Did I read that correctly? I am having the exact same problem!!
  3. #18
    Dec 2018
    greenville, nc
    Quote Originally Posted by CHOPPER936 View Post
    I was not getting a psi reading on my smartcraft gage, just read 0.0 all the time. I assume this would mean the sensor is not reporting data to the ecm as well. As soon as I installed the original pn sensor, the gauge starting reading psi and problem solved. Mine is a 2000 model.
    Another cause could be the in gear switch underneath the shifter rail. My understanding is this switch tells the ecm the motor is in gear and to look for certain info from sensors, ie, wp sensor.
    hope this helps
  1. 2000 150 Optimax pressure alarm, bypass sensor?
    By Stevebbc in forum Technical Discussion
    Last Post: 03-16-2019, 10:44 AM
  2. Mercury Tech: 2000 150 Optimax pressure alarm
    Last Post: 03-15-2019, 07:24 PM
  3. Mercury Xr6 water pressure and alarm help
    By dblount in forum Technical Discussion
    Last Post: 04-10-2017, 02:06 PM
  4. No water pressure alarm
    By unknown1 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-25-2016, 06:57 PM
  5. 93 2.5l xri 200 loses water pressure when up on plane
    By seef158 in forum Technical Discussion
    Last Post: 05-05-2014, 07:30 PM
