Results 1 to 15 of 22
    Jun 2001
    1976 Merc 1500 Shorty
    1976 Mercury 1500 Short Shaft
    Serial number - 4748320. Numbers matching on block and midsection.
    Powerhead- completely torn down, media blasted to bare metal, baked on primer and painted with 2 coats of high-quality Acrylic Urethane. Block is still standard bore, pistons weight matched to within .5 grams. All new bearings, rings, seals. Bores were lightly honed and within .002 of nominal spec. Labyrinth seals on reeds measured and within normal limits. All high dome, three ring pistons installed. Carbs soaked, cleaned and rebuilt with new gaskets, needles and seats. Fuel pump soaked and cleaned and rebuilt with new parts. New timing belt. Brand new starter. All gas lines replaced with new ethanol resistant hose. All wiring in excellent shape. Compression before first start is 137-142 on all cylinders. This is NOT a J block motor.
    Midsection- Completely disassembled, blasted, primed and painted same as powerhead. New Solid mounts upper and lower. Swivel pin has no play in the bottom bushing. Comes with trim rams but NO HOSES OR PUMP.
    Lower Unit- Disassembled, blasted, primed and painted as above. New seals and new upper driveshaft bearing. Lower shimmed to factory specs. Pressure tested to 15 lbs for overnight. Straight cut 2-1 gears installed. All gears in excellent condition. One scratch on the bullet of the gear case from moving it around in the garage. DAMNNNN !!!!!!!!!
    Cowling- louvered cowling stripped and painted. No dents or dings. 7 or the eight screens are INTACT. New Repro decals installed. No bubbles or creases. Latches all work smooth. Looks as good as factory. This cowling alone is worth $600 in this condition.
    Motor only has an hour of break in time on a test stand with 100 Av Gas. It will need full break in and final timing checked and set. Carbs will need minor tweaking when in the water.
    No prop, gas tank, controls, trim hoses or trim pump included. Will test run on test stand and answer any an all questions. Bring your own guy to check it out if you wish. Will provide detailed pics of any part of the motor that you want.
    If you want a discount, I will keep the louvered cowl and sell for $4000
    Used motor sold AS IS / WHERE IS. Located in Palm Bay, FL. Zip code 32905
    WILL NOT SHIP
    $4500
    Attached Thumbnails Attached Thumbnails IMG_1473.jpg   IMG_1476.jpg   IMG_1472.jpg   IMG_1477.jpg   IMG_1478.jpg
  2. Likes W2F a V-King, Capt.Insane-o liked this post
    Jun 2001
    sorry about th epics. No clue why they are sidewyays.
  4. Thanks specboatops thanked for this post
    Likes specboatops liked this post
  5. #3
    Jun 2001
    or trade for T2 T2X stuff...
    goddamn taxes.
    May 2001
    Ga
    Nice looking merc .
  8. Likes Turtleherder liked this post
    Jan 2019
    Utah
    That is a beautiful motor! Hope to learn to perform that quality of work someday. (Recently picked up a few inline 6's to practice on )
    Good luck with sale.
    Aug 2015
    NE Tennessee
    Yes, everything he does comes out really nice.
    I saw one of his I6 motors (1973 Blue Stripe 1500 ) on a friends 15 ally...Boat and motor both sweet...The motor was redone by Tom S.
    The boat done by (OldSkier) Bernie.
    Black Creek WI
    Very nicely done
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
    Feb 2007
    Western Washington State
    Damn beautiful motor, man. Classic outboards/boats aren't like classic cars, sadly.
    Jun 2001
    Family isues dictate rasing some cash. New price $4000. Need to sell ASAP
    Tom
  14. #11
    Mar 2003
    Belvidere IL, FARM
    Very Sharp and nicely done!
    God, Country, and Fast Boats
    Apr 2018
    Maine/Ma
    Beautiful job for sure, just don't see um like that often.......Boy does that motor bring back memories.....
    spent the summer of 1975 in Charleston SC with relatives, water skied every day and on several occasions there were a pair of brothers that had matching 15' Checkmates with Merc 1500's on them......Hmmmm.....maybe that was where i was first bitten by the "Scream and Fly" Bug?
  16. #13
    Jun 2001
    Still for sale......
  17. #14
    Jun 2001
    bump one time.....
  18. #15
    Jun 2001
    Last change in price before it goes into the living room. $3500 CASH, pick up only. with the cowl...
  1. 1976 1500 inline 6 prop HP?
    By KG4 in forum General Boating Discussion
    Last Post: 04-19-2019, 05:36 PM
  2. 1976 1500 gear ratio
    By Chuck Mostaka in forum Props, Setup, and Rigging
    Last Post: 11-26-2007, 05:29 PM
  3. Gear ratio for a 1976 1500 L6
    By KG4 in forum Technical Discussion
    Last Post: 01-18-2006, 09:22 AM
  4. 1976 1500 Mercury
    By Mickdund in forum Outboard and Racing History
    Last Post: 07-24-2002, 02:02 PM
