Results 1 to 12 of 12
    Jun 2013
    Minnesota
    Wh-18 on horizontal reed 2.4
    My original motor was a verticle reed 2.4 200. I put the carbs on my horizontal 200 that has 4 petal reeds and cherry 2.4 mods. The .062 jets seem small. Everywhere I look I see guys saying 86 88. Is there something internally different on these or should I jump up. Or find a set of 22's.
    Thanks
    Sep 2017
    Ashland city tn
    Wh 18s were round bowl carbs if I'm correct , the 2.4horizontal came with 74 and 76s in the 22s, them merc moved em up to 80 82 I believe ,,, if it's on a mod 2.4. With horizontal, then 62 would seem like it would melt it down
    What's the mods for the horizontal 2.4?
    Jun 2013
    Minnesota
    Windowed pistons, cut heads, cut chest, .050" decked front, intake port matched to reed blocks and radiused sharp corners. Are the major things I can think of.
    Jun 2013
    Minnesota
    Are the 22's square bowls? Is there more volume? Reading on cor racing web page all carbs with 1374-5427 cast in have the same venturi but it would also lead me to believe that they are the same raw casting and machined differently.
    Jul 2012
    Lufkin, Texas
    22’s should be square bowls. Round and square bowls are interchangeable, the carb casting is the same. If you drill and add the primer fittings to the bottom two carbs on a round bowl setup you can convert to the enrichiner system. I made a post about it a few years ago, a search would probably pull it up...
    Josh Peterson
    Sep 2017
    Ashland city tn
    I also did enrichment system to round bowls like the 18s , but yes square bowls is more volume
    Jun 2013
    Minnesota
    Well I'm going to grab a set of 34's tomorrow. The 18's had an enricher that fed from top carb to bottom 2. I'll have my new switch boxes and be able to fire it up. Was running on 5 for the first fire.
    Sep 2017
    Ashland city tn
    Good cause I was wrong. Guess I was thinkin 16s. The 18s came from 150 with square bowls
    Sep 2017
    Ashland city tn
    What did u ever do with the wh18s? I could really use main jets out of em if they r stock , mite b idles idk but I think they r in 56ish range. Wanna sell? Trade?
    Jun 2013
    Minnesota
    I have them in the 34's right now, they were .068 and #5 was something else can't remember. I was going to drill them out cause I'm impatient and want to start breaking it in this weekend. You can go on Amazon and get holley air bleed jets for ~$15 for 8 and they are the "Same".
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Gmcviper View Post
    I started lookin at Holley jets. What # jet would I need for 52s 54s? Their numbering looks different
  12. #12
    Jun 2013
    Minnesota
    The air bleed jets are the size in thousandths same with merc.
  1. Mercury Tech: Clamshell Cowl from vertical reed , need to use on a horizontal reed engine. How?
    By Zoomba in forum Technical Discussion
    Last Post: 04-25-2015, 11:17 PM
  2. 2.0 horizontal reed blocks?
    By dtmeeks in forum Technical Discussion
    Last Post: 09-06-2010, 11:58 PM
  3. vertical reed vs horizontal reed
    By capnzee in forum Technical Discussion
    Last Post: 04-09-2009, 11:01 AM
  4. Pre 83 225 Reed Horizontal???
    By djtalon in forum Technical Discussion
    Last Post: 10-09-2002, 06:41 AM
