Results 1 to 8 of 8
    Feb 2019
    Gainesville fl
    87 200 blackmax vacuum line replacement
    I am replacing all of the lines under the cowl and was curious if the length of the vacuum lines matter? Also was in the process of deleting oil injection and seems as though I have the wrong kit, can someone varify?Click image for larger version.
ID:	434126Click image for larger version.
    Jun 2018
    Floating around
    Length shouldn't matter much. Not nearly as much as cracked leakers thats for sure. I can see some logic in having them all the same length but first Ive heard of it plus im curious about what your doing for oil inj delete so i'll see what others have to say there. I have a motor now that has a hose and bolt clamped over the port and thats it so I dont think it needs much.
    Feb 2019
    Gainesville fl
    The lines are not all the same length as of now, but I wanted to clean everything up and shorten the lines. As far as deleting the oil injection I bought a kit 43453Click image for larger version.
ID:	434127T and the bolt holes dont line up and it wont go all the way in. Click image for larger version.
    Feb 2014
    Missouri
    Only matters on supper sensitive vacuum lines. Can also affect short pulse signal.
    Shouldnt ever have much much to do with outboards as it takes several feet.
  5. Likes Blkhoe liked this post
    Pekin, IL
    Length of hose bleed lines does not matter. Block off only fits in one direction. Also seen some that did not want to fit with oring so I make a small gasket.
    Rock
    Team Junk
  7. Likes Blkhoe liked this post
    Put zip ties on the ends of the hoses, try 180 on the block off has a cut out that must go towards the crank gear. Make sure there is an o-ring to seal the top, don't see it in the pic.
  9. Likes Blkhoe, W2F a V-King liked this post
    Jun 2013
    Minnesota
    Is it very critical to get the lines to the "correct" cylinder? I put 1-3, 3-5, 5-1 cylinder to intake. Same on other side just even #'s.
    Aug 2015
    NE Tennessee
    Crack open the shop manual, there are diagrams for proper bleed line routing.
    +1 on the zip ties or small pinch clamps for the bleed line connections.
  1. Mercury Tech: Fuel line, vacuum hose, and water line replacement
    By RHafley in forum Technical Discussion
    Last Post: 12-23-2017, 08:43 PM
  2. Vacuum line on ecu
    By blowitup in forum Technical Discussion
    Last Post: 07-06-2016, 02:27 PM
  3. 225 Promax vacuum line portside vst help ...Please
    By woundedwarrior in forum Technical Discussion
    Last Post: 09-10-2014, 12:33 PM
  4. Mercury Tech: 1987 V200 Blackmax stator replacement.
    By graham180869 in forum Technical Discussion
    Last Post: 08-25-2012, 09:52 AM
