Results 1 to 5 of 5
    May 2013
    WV
    Question 1999 2.5L 200 EFI question.
    Removed the heads from my old motor today. #5 & #6 pistons look like they weren’t getting oil. But the other pistons and cylinders look fine. Where can I send my injectors to be cleaned and tested? Should I be looking at anything else before assembling my replacement? I plan on pre-mixing the new one.
    Pekin, IL
    I like Brendan Power. Brucato does well also.
    Rock
    Team Junk
    May 2013
    WV
    Since there was rust present in both cylinders, could it be possible that the gasket between the block and midsection blew?
    I’m planning on lifting the block off of the midsection this evening.
    Pekin, IL
    That is entirely possible. I had one years ago that kept killing 5 & 6 and it turned out to be a crack in the divider tween exhaust ports on bottom of block. Hopefully yours is just a gasket.
    Rock
    Team Junk
    May 2013
    WV
    I bought another shortblock to replace this one. Just curious as to what caused it to blow.
  1. 1999 Merc 3.0L 250 EFI question
    By WVBassman in forum Technical Discussion
    Last Post: 03-03-2019, 08:00 PM
  2. 1999 Mercury 250 EFI question
    By Trident in forum Technical Discussion
    Last Post: 10-07-2014, 10:04 AM
  3. Johnson 1999 90 HP Electrical question
    By Tom Foley in forum Technical Discussion
    Last Post: 09-21-2010, 06:43 PM
  4. 1999 Chevy 1/2 ton Question
    By Pro300x24LD in forum Other Motorsports
    Last Post: 10-30-2006, 01:06 PM
  5. 1999 225 Pro Max - stupid question
    By Greg in forum Technical Discussion
    Last Post: 12-23-2003, 10:18 AM
