Page 7 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 91 to 105 of 205
  1. #91
    Jul 2005
    AZ
    So it's 20* btdc?
    '84 Checkmate Convincor
  2. #92
    Mar 2019
    Atlanta GA
    So it's 20* btdc?
  3. #93
    Jul 2005
    AZ
    Quote Originally Posted by jaymalyon View Post
    So it's 2* advanced turn it clockwise 2 turns check it again should be 18btdc..
  4. #94
    8 Post(s)
    You should check the timing pointer with a piston stop first
  5. #95
    Jul 2005
    AZ
    Oh so still can't get it over 3900?
  6. #96
    Jul 2005
    AZ
    Was motor High enough that it didn't have full load at the prop? If it's electrical or fuel.!?!
  7. #97
    If you haven't replaced the plug wires. Those are solid core wires? I'd thoroughly check everyone end to end for continuity while gently twisting them. Better still pull the boots off each end, cut a 1/4" or more off each end and set the clip in new wire if it's still good and not burned or corroded, if you have enough slack to still make the distance, coil to plug.
  8. #98
    Mar 2019
    Atlanta GA
    It is good.
  9. #99
    Mar 2019
    Atlanta GA
    Correct.
  10. #100
    Jul 2005
    AZ
    Oh you replaced plugs not wires too?
  11. #101
    Mar 2019
    Atlanta GA
    Could not get to full load. Still only hitting 3900 rpms
  12. #102
    Mar 2019
    Atlanta GA
    Have not changed plug wires.
  13. #103
    Jul 2005
    AZ
    Oh meant was prop able to slip being higher, making it easier for it to rev up in gear?
  14. #104
    8 Post(s)
    Did you pull the airbox and check all 6 carbs open?
  15. #105
    Mar 2019
    Atlanta GA
    Yes. All 6 are synced and opening all the way at full throttle.
  1. OMC Tech: evinrude 9.9 to 15 hp conversion?
    By JoshKeller in forum Technical Discussion
    Last Post: 10-09-2019, 07:54 AM
  2. 1989 Evinrude 100 XP 20" Shaft Length
    By huskerdu in forum Outboard Engines
    Last Post: 04-13-2016, 12:44 PM
  3. 1989 Evinrude 150 XP vs. 1986 Evinrude 150 Special Edition
    By KOMotion in forum Technical Discussion
    Last Post: 10-31-2009, 11:44 AM
  4. weight of 1989 XP 150 20"shaft evinrude
    By dnman in forum Technical Discussion
    Last Post: 08-24-2006, 05:31 PM
