Page 6 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 76 to 90 of 205
  1. #76
    Jul 2005
    AZ
    Quote Originally Posted by jaymalyon View Post
    Ok that sounds easy enough.
    Been trying to back track today and determine what I could have done to alter the timing. Would replacing the flywheel do it? The one I am running now is not the original, it is off of the same model though.
    I wasn't really pleased with how freely the timer base was moving this evening, seems like it might be sticking, so I am going to dig a little deeper into that as well.
    Anytime you change a timing base you should check the timing
    '84 Checkmate Convincor
  2. #77
    8 Post(s)
    Flywheel got lots to do with timing, there is a diagram on CDI web site showing where the hub should be, they can slip.
    twin pack flywheel different than single pack re the timing hub
    Which ignition system do you have?
    Flywheel and timer base need to be used as a pair for these versions
  3. Likes jaymalyon liked this post
  4. #78
    Jul 2005
    AZ
    You said it wasn't revving up before you switched the flywheel..correct?
  5. #79
    Mar 2019
    Atlanta GA
    Better to ask three times then ruin something
    No not really a way to check on the hose...
    Except.. but this really isn't accurate take plugs out push the throttle all the way up then crank motor over see what timing light shows..should be around 14* btdc
    No wot can't be done on the hose or at idle
    It can be timed perfect at idle and be out at wot
    There are two timing stops, idle is the one on the starter side which you can check idle..but you said it's idling fine 900 out of gear and 600 in gear +-?
    The stop on the other side is wot make sure it's hitting that stop
    Ok what you could try is warm the motor up then take the rubber cap off wot stop put in gear and take off see if that changes anything BUT don't run it long just a quick
    Haha that's what I was looking for.
    Yes, idle seems to be fine, a tad high if anything.
    Sorry for all the questions, timing these strange animals has always been a mystery to me. Just looking for a test to fail before I proceed further. I'm feeling as though we are on to something though...
  6. #80
    Mar 2019
    Atlanta GA
    35 amp and single power pack. I have a picture of both flywheels side by side, they are identical. I'll see if I can find it.
  7. #81
    Mar 2019
    Atlanta GA
    Correct. The flywheel magnets broke loose with the 25" midsection and I changed everything after. Didn't run it again until after the swap.
  8. #82
    Mar 2019
    Atlanta GA
  9. #83
    8 Post(s)
    look for the gap in the stainless ring on the hub, with the key at 12:00 one split should be 2:30, other almost at 7.00
    put a marker pen mark at key and the splits and post a photo
  10. #84
    Mar 2019
    Atlanta GA
    Pulled the flywheel and oddly enough, it looks someone has already made the marks in those locations. I bought this flywheel from a junkyard so who knows the history.
    Attachment 435862
    Attachment 435864
    I see the gaps you are talking about in the stainless ring. I noticed they are full of metal debris. Possible the magnet picked it up from when the magnets in the last flywheel came apart. Would that cause a timing issue?
    Attachment 435863
    Took a closer look at the spark advance tube and pulled it apart. Full of gunk and some weird dust. Cleaned it up and greased the hell out of it. Seems to be moving freely now. It has to make a difference.
Name:	Screenshot_20190409-205526_Video Player.jpg
  11. #85
    8 Post(s)
    photo links not working
  12. #86
    With the wheel off and moving the throttle to full advance did it reach the stop?
  13. #87
    Mar 2019
    Atlanta GA
  14. #88
    Mar 2019
    Atlanta GA
    "With the wheel off and moving the throttle to full advance did it reach the stop?"
    Yes. But before I pulled it apart and cleaned it, it was sticking and not exactly moving freely.
  15. #89
    8 Post(s)
    you might have solved it
  16. #90
    Mar 2019
    Atlanta GA
    On the water now. Checked timing as wide open as I could (still 3900) and the pointer is on 20 degrees on the starboard side of the scale. I know I'm looking for 18 degrees but the only mark I can see is on the port side of the scale on the flywheel. Is it possible my timing is that off? Seems like a hell of an adjustment.
  1. OMC Tech: evinrude 9.9 to 15 hp conversion?
    By JoshKeller in forum Technical Discussion
    Last Post: 10-09-2019, 07:54 AM
  2. 1989 Evinrude 100 XP 20" Shaft Length
    By huskerdu in forum Outboard Engines
    Last Post: 04-13-2016, 12:44 PM
  3. 1989 Evinrude 150 XP vs. 1986 Evinrude 150 Special Edition
    By KOMotion in forum Technical Discussion
    Last Post: 10-31-2009, 11:44 AM
  4. weight of 1989 XP 150 20"shaft evinrude
    By dnman in forum Technical Discussion
    Last Post: 08-24-2006, 05:31 PM
