Page 3 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 31 to 45 of 205
  1. #31
    Feb 2014
    Missouri
    If you have it. It pushes in fuel when you increase the throttle. Over what flows in from fuel pressure and vacuum draw. It’s literally a squiter some even look like the spring and piston on a squirt bottle. That little bost can get you over a hump.
    Fast start advances timing when it’s cold if not disabled the initial timing is about 4-5* retarded. Don’t go off that though it’s different for each. Once warm the timing would be off and power drop.
    Tell us us a little about the low rpm and middle and cruise performance. Does that feel the same? We might narrow down something if say oh under 3500 it’s running the same.
    Edit: a oil delete specialist might want a description of the oil delete could be something missed.
  2. #32
    Mar 2019
    Atlanta GA
    Idle, Low rpm and cruise all seem fine to me. No misses, surging, or anything like that. Smooth all the way up to 4000 and then the motors sounds like its got more in it, but cant get past it. It's not like its screaming wide open but not turning enough rpms. Its just not getting there. It fluctuates just a bit when you hold it wide open as if you were wiggling the throttle back and forth or something. Sometimes, it wont even get to 4000.
  3. #33
    Assuming everything checks out, including temperature, leak down .
  4. #34
    8 Post(s)
    Quote Originally Posted by jaymalyon View Post
    Fuel consumption seems to be the same as always. Guzzles it.
    After the midsection swap, the motor ran at 4000 rpms until I cleaned and rebuilt the carbs. It then ran 5500 briefly, then back to 4000. This occurred between October 2018 and February 2019. Had it out last weekend after replacing the stator and fresh plugs and it was still the same.
    I'm going to go back through the carbs and replace the fuel lines and see what happens.
    Will this fuel pressure gauge work or do I need something outboard / 2 stroke specific?
    Attachment 434055
    just need any old gauge to check it has some pressure before the carbs
    Some hose and a tee piece
  5. #35
    Mar 2019
    Atlanta GA
    Ok got it. If the motor will turn 4000 rpms is there a reason to believe it would not have fuel pressure? I would think if there was zero pressure it wouldn't run at all, right? But if the pressure was not as high as it should be, would that cause a lack of wide throttle?
  6. #36
    Nov 2003
    Last summer I chased a similar gremlin on a 2001 Johnson 225 HO. Drop cylinders won't rev over 4500. Couldn't make it happen on the Dyno. Short story.... While the flywheel was off I noticed the Timer base magnet in flywheel was weak compared to another flywheel I had. Installed the other wheel and the problem disappeared.
  7. #37
    8 Post(s)
    yes it runs out of fuel at WOT, you need to check before you kill it
  8. #38
    Mar 2019
    Atlanta GA
    Quote Originally Posted by skiboater View Post
    That is strange. I have my old flywheel but no magnets. Might be worth trying to repair it for a test?
  9. #39
    Mar 2019
    Atlanta GA
    I was afraid of that.
  10. #40
    Mar 2019
    Atlanta GA
    I opened the carbs back up and confirmed I have the correct jets. Stamped "62D". Also gave them all another thorough cleaning.
  11. #41
    Feb 2014
    Missouri
    That kinda sound like the protection circuit is active.
    Hears one. Does it slam into a wall at 4000. Or does it struggle to get there and just barely make it?
  12. #42
    Mar 2019
    Atlanta GA
    Slams into a wall. Definitely not struggling.
  13. #43
    Western Pennsylvania
    Attachment 434055
    Looks like it goes to 100 PSI and since you have carbs my guess PSI is in the 5-7 range?? That kits for EFI system.
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  14. #44
    Feb 2014
    Missouri
    Slam into a wall to me sounds like a limiter is active. The sputtering and stuff would be it dropping cylinders.
    Check the buzzer to see if it works or has been disabled. And it’s probably related to the oil delete. One of the sensor tie offs or wires not terminated correctly sending it to limp mode.
    Someone else will will have to walk you through though one of the few things I haven’t messed with. Other then finding them with it done wrong.
  15. #45
    May 2001
    Hickory NC
    Oil delete you just need to plug oil fitting on pump and disconnect the wires coming from pump, and mix at 50 to 1. Slow should hold engine to 2500 however. Since you have had ignition off have you checked wire color coding to the coils?
  1. OMC Tech: evinrude 9.9 to 15 hp conversion?
    By JoshKeller in forum Technical Discussion
    Last Post: 10-09-2019, 07:54 AM
  2. 1989 Evinrude 100 XP 20" Shaft Length
    By huskerdu in forum Outboard Engines
    Last Post: 04-13-2016, 12:44 PM
  3. 1989 Evinrude 150 XP vs. 1986 Evinrude 150 Special Edition
    By KOMotion in forum Technical Discussion
    Last Post: 10-31-2009, 11:44 AM
  4. weight of 1989 XP 150 20"shaft evinrude
    By dnman in forum Technical Discussion
    Last Post: 08-24-2006, 05:31 PM
