Results 136 to 150 of 205
10-07-2019, 11:36 AM #136Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
OK! ... Cold engine run @ 4000 (Which is still awfull) but then after five minutes it drops to 3300?! You have to consider a thermal related problem, which is 99.9% chance of an electrical related component failure. Something is changing as the engine reaches operating temp. A pack or stator going south as they get hot. (Cold solder joint changing resistance etc.) I'm leaning away from a fuel related problem just for now.
Ok, more basics. Do you have a breakout box where you can read charge coil voltage while under way with a peak reading volt meter?
I haven't read all nine pages of posts, so please forgive me if I repeat a sugestion someone else has already made.
10-07-2019, 11:46 AM #137Member
- Mar 2019
- Atlanta GA
- 82
- 7
- 16
10-07-2019, 11:54 AM #138Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
Yep...should be fine. Test output cold with plugs out for max cranking rpm. Run engine until rpm drop occurs. then back to the doct and repeat test, and see if you've got a drop in voltage. Don't let the engine cool off before testing.
What is the rpm drop like , fast, or like a slow bog?
10-07-2019, 12:08 PM #139Member
- Mar 2019
- Atlanta GA
- 82
- 7
- 16
Slow. Like you were backing off the throttle.
FYI, somewhere in the last 10 pages I discussed a fluke where the motor did run ONCE between 5200-5400 after the conversion. Full power and hauled ass. This was the first pull after I rebuilt the carbs and then right back to where we are now.
10-07-2019, 12:15 PM #140Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
Going back to that broken timer base advance adjustment linkage ... When the throttls is in WOT position (Engine not running) can you go back and move the timer base back and forth?
10-07-2019, 12:25 PM #141Member
- Mar 2019
- Atlanta GA
- 82
- 7
- 16
10-07-2019, 06:05 PM #1426000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Heh this would be funny after all this, but you didn’t accidentally bump that one lever after the install the one that has three positions one for fogging or something.
10-07-2019, 06:56 PM #143Member
- Mar 2019
- Atlanta GA
- 82
- 7
- 16
10-07-2019, 06:59 PM #144Member
- Mar 2019
- Atlanta GA
- 82
- 7
- 16
10-07-2019, 07:09 PM #145Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
OK Good.
Motav18 touched on something. I've had bad enrichener valves go bad and leak internally. Remove the two small delivery hoses from the solenoid and squeeze the primer bulb, see if you have any fuel squirting out, it's a stretch because usually there failures won't let the engine idle. If you do, remove the larger supply hose, plug it and test run the boat.
10-07-2019, 07:20 PM #146Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
Johnson / Evinrude primer solenoid Video
https://youtu.be/BrBj2p4A8xQ
10-07-2019, 07:30 PM #147Member
- Mar 2019
- Atlanta GA
- 82
- 7
- 16
Dangar Stu! Love that guys videos. I got very familiar with them when I was in the depths of the conversion last year. Brandon's Garage is another good channel. I just about had his lower unit rebuild video memorized I watched it so many times.
As far as the primer solenoid goes, I have replaced it recently and know that it works. I usually hold my key down for about 10 seconds and the motor will fire up on the first turn of the key.
10-07-2019, 09:52 PM #1486000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Along the solenoid I assume down.
Do do you have a cold hot or on/off stop on the linkage. It’s a limiter for cold weather so you don’t need two props for cold and hot by limiting carb opening when cold. If you do and it’s set to on it will mess up synch if you redo it and limit rpm up to 3/4 throttle.
Cant remember if yours has one they appear randomly or were removed a lot.
Just shotgunnin it this point.
10-08-2019, 02:22 PM #149Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
The fair rpms for five minutes and the loss of power points to electrical. But the slow return to 3300 sounds like fuel. Insert a piece of clear fuel line to the fuel inlet and outlet side of the VRO. As the VRO heats up it could open a crack between the air motor side and the outgoing fuel side. Watch for bubbles in both hoses. but if supply is clear, and discharge is foamy, you've got an internal leak. But make sure the pulse hose is tight and you have the blue pulse restrictor. Other that that start back with degreeing the flywheel and eliminating good ignition components from the equation.
10-08-2019, 02:25 PM #150Member
- Mar 2019
- Atlanta GA
- 82
- 7
- 16
OMC Tech: evinrude 9.9 to 15 hp conversion?
By JoshKeller in forum Technical DiscussionReplies: 24Last Post: 10-09-2019, 07:54 AM -
1989 Evinrude 100 XP 20" Shaft Length
By huskerdu in forum Outboard EnginesReplies: 1Last Post: 04-13-2016, 12:44 PM -
1989 Evinrude 150 XP vs. 1986 Evinrude 150 Special Edition
By KOMotion in forum Technical DiscussionReplies: 10Last Post: 10-31-2009, 11:44 AM -
weight of 1989 XP 150 20"shaft evinrude
By dnman in forum Technical DiscussionReplies: 1Last Post: 08-24-2006, 05:31 PM
