Results 1 to 6 of 6
    Nov 2018
    parker, Tx
    Water in 2.5l mercury 200 cylinder
    Hey yall, I first noticed a white milky mixture on my spark plugs. I figured it was the head gaskets as the compression test was low and my boat struggled to get out of the hole. I replaced the head gaskets on both sides, the right bank was clean and the pistons all looked good. The left side had water droplets all in it. Figuring it was the head gaskets, replaced them and the compression was good. Ran the boat for a couple months and now it is really bogging down, when I unplug the top left and bottom left spark plugs nothing changes in the idling of the engine, they are still sparking good. But the plugs where very milky. Worse than before. What could be causing this? The engine is a 1998 2.5l v6 and has been used a lot. Its carbed. Compression was 115-120 on all 6 cylinders.
    Tha k you
    Jan 2003
    aalsmeer
    possible powerhead to mid plate gasket failure!
    Attached Images Attached Images
    Sep 2017
    Ashland city tn
    Quote Originally Posted by PanRonnie View Post
    Yep I'm gonna say ph gasket also , and will wreak havoc on a mota
    Aug 2015
    NE Tennessee
    Agree, save for why cyl #2 has water in it ....
    Can exhaust pulses carry water to the top cylinder from the base gasket?
    Apr 2007
    Wilkesboro, NC
    A leaking exhaust cover gasket can cause this as well. That one is not to hard to replace either.
  7. Likes FMP liked this post
  1. OMC Tech: 60* 150 getting water in cylinder
    By mn808gade in forum Technical Discussion
    Last Post: 06-17-2016, 06:35 AM
  2. Mercury Tech: 2.4 200 water in cylinder
    By speedinstream in forum Technical Discussion
    Last Post: 03-19-2010, 06:06 AM
  3. Water in Cylinder?!?!?!
    By P man in forum Technical Discussion
    Last Post: 08-21-2008, 01:54 PM
  4. water in the cylinder.
    By Big Johnson v6 in forum Technical Discussion
    Last Post: 03-11-2007, 08:36 PM
  5. Water In Cylinder
    By VISION 51 in forum Technical Discussion
    Last Post: 12-02-2004, 07:16 PM
Spinelli Props
