Results 1 to 10 of 10
    Mar 2017
    virginia
    2000 mercury 225 efi yard running
    things are warming up and getting the fleet in order. my merc 225 has factory lwp in the bullet. will it run off the water muffs, or do i need to submerge the lower unit?
    thanks
    you need to block the 4 holes on the bullet to use muffs. Why not use the flush on the motor by the exhaust on the lower cowl?
  3. Thanks bill6ft6 thanked for this post
    Mar 2017
    virginia
    damn, ya made me look!! nope, don't have one. sure would have been the easy solution
    is your 225 a 3 liter? If so this is a pic of your exhaust plate and you have a fitting on part number 20 which has a hose fitting where part number 24 is
  6. Thanks bill6ft6 thanked for this post
    Mar 2017
    virginia
    my hats is off to you sir. thank you
    Dec 2012
    tn
    This was specifically not recommended on 2.5s
    Quote Originally Posted by CircleHook View Post
    Probably the reason the 2.5 exhaust plate does not have this feature.
    Dec 2012
    tn
    Go look- later model stuff certainly does have the flush port. One of the reasons listed was water pump would be run dry.
  11. Thanks bill6ft6 thanked for this post
    Any way on the 3.0 you can run the motor up to 1500 rpms on flush attachment . On my X we have to run muffs and on the flush attachment to keep it cool on the dyno.
  13. Thanks bill6ft6 thanked for this post
    Dec 2011
    Ottawa
    Good ol duct tape on nose and normal muffs on side
  15. Thanks bill6ft6 thanked for this post
  1. Complete EFI / CDI System from running 2.5L 2000 200 EFI 2 Stroke For Sale
    By ibhurln in forum Misc. Parts and Accessories
    Last Post: 07-14-2018, 07:09 AM
  2. Mercury 175 Running Rich. Rough to 2000 RPM.
    By Capnmoench in forum Technical Discussion
    Last Post: 09-13-2017, 07:44 PM
  3. Mercury Tech: Motor not running above 2000 rpms...
    By SodarSki73 in forum Technical Discussion
    Last Post: 10-18-2012, 03:20 AM
  4. 2000 Ficht 115 Running Rough/missing
    By jacklake2003 in forum Technical Discussion
    Last Post: 07-20-2009, 10:36 AM
