Results 1 to 6 of 6
Thread: effect of 'hook' on speed?
03-15-2019, 04:49 AM #1Member
- Apr 2017
- nunya business
- 36
- 25
- 19
Hi all,
Have just been trying to diagnose my boats difficulty in revving, a page i read on here suggested that hook might slow a vessel down, so i got a straightedge and have just realised i can easily fit a coin between straightedge and hull on both sides, is this normal for such a small (14ft) vessel and would it possibly rob me of upper rpm partly due to a 14 1/2 inch diameter prop?
03-15-2019, 07:34 AM #2
Some boats develop a hook from improper trailering and some have hook built in. A built in hook will possibly slow you a bit but it's most likely there to help keep the nose down. A perfectly straight bottom is usually fastest.
RockTeam Junk
XstreamVking liked this post
03-15-2019, 12:25 PM #3
Sounds like a soggy boat with a weak bottom.
03-15-2019, 12:28 PM #4
Sometimes they will add hook to the outside of the hull to help plane and low speed performance. Is the hook also present in the pad?
03-16-2019, 02:52 AM #5Member
- Apr 2017
- nunya business
- 36
- 25
- 19
capt insane, lol, boat has had new floor fitted and foam filled, is dry as a bone, thanks for your creative insight and possible cause though...
03-16-2019, 02:55 AM #6Member
- Apr 2017
- nunya business
- 36
- 25
- 19
its just a v all the way, there isnt a pad, well yet anyhow, hahaa, never know as it seems like a never ending project...
Setback effect on blowout speed?
By aaronmt73 in forum Props, Setup, and RiggingReplies: 9Last Post: 07-28-2013, 11:18 PM -
hook or no hook on my viper????
By Fasttoys in forum Props, Setup, and RiggingReplies: 4Last Post: 06-10-2007, 08:12 PM -
Trim seems to have no effect!
By Rush in forum Props, Setup, and RiggingReplies: 11Last Post: 06-04-2005, 10:43 AM -
Height of pad? What effect does it have?
By sho305 in forum Props, Setup, and RiggingReplies: 5Last Post: 10-21-2002, 09:33 AM
