Results 1 to 1 of 1
03-13-2019, 04:48 PM #1Junior Member
- Aug 2007
- AZ
- 12
throttle stop adjustment, Pressure Regulator housing broken - merc 250 3.0 EFI
new to me project. When looking over engine, noticed a couple of items and hoping some can assist:
1. the motor has a throttle stop adjustment on the linkage on the motor. If I manually open the throttle, I notice the top butterflies are not completely open. About 30% left to make WFO. Is this something I can adjust or is this a normal situation?
2. The vac line that goes to the fuel pressure regulator is not attached, easy fix. I assume this controls the return line pressure?
3. The assembly with the schrader valve(to check pressure) is cracked at the base where it mounts to the block. Is this a part I can get my hands on?
Engine has 300 hrs on it. I am planning to have heads cut, reeds replaced and have Simon do the boxes. Want to take this to 300PM levels.
Thanks in advance
noli liked this post
Merc 200XRI fuel pressure regulator
By One More Year in forum Technical DiscussionReplies: 6Last Post: 06-17-2013, 12:12 PM -
WTB - Merc 2.5L 280 Adjustable Fuel Pressure Regulator
By wagoetzmann in forum General Boating DiscussionReplies: 0Last Post: 03-19-2012, 06:36 AM -
OMC Tech: Setting for Idle Stop Adjustment Screw X-Flow
By LSaupe in forum Technical DiscussionReplies: 6Last Post: 04-29-2011, 06:06 PM -
300 xs throttle adjustment
By FUN4ME in forum Technical DiscussionReplies: 2Last Post: 05-09-2008, 06:59 PM
