Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
    Sep 2017
    Ashland city tn
    Ur gonna need a 4 or 5 in jackplate,,they r 4 sale pretty cheap here and there,,powerpacks only if ones messed up,(not firing)
    U really need water pressure guage and can b obtained really cheap and very easy install, but I would least raise motor up on transom if it will allow , prob start round 2 1/2 in under pad (prop shaft) how many bolt holes can u come up on transom?
  2. Thanks thunder77 thanked for this post
    Likes thunder77 liked this post
  3. #17
    Apr 2017
    nunya business
    can go up 2 more holes, but top of bracket will be above transom, will this be ok or should i look at somehow trying to build it up higher or just make jack plate?... will this setup be good in choppy water and will i need to change prop at same time? thanks
  4. #18
    Sep 2017
    Ashland city tn
    Ya b fine n chop cause ur no where near bottom yet, u definitely need a stainless prop but I wouldnt just yet , how bout raise it 1 hole on transom c what it does
  5. Thanks thunder77 thanked for this post
  6. #19
    Apr 2017
    nunya business
    will do that now and try it out on water tomorrow and get back to you, thanks for taking the time to reply,
    regards
  7. #20
    Sep 2017
    Ashland city tn
    No prob, but u can go ahead plan on buyin/building jackplate
  8. Thanks thunder77 thanked for this post
  9. #21
    Sep 2017
    Ashland city tn
    These r just tips to get max performance, u can always drop down prop size and b done , but if u had ss prop and plate it's a big difference, take a timin lite to lake and make sure all 4 firing
  10. Thanks thunder77 thanked for this post
  11. #22
    Jan 2015
    I read and replied to your other thread regarding your motor with the linkage being synchronized and the motor timed correctly. I can only recommend that until you have the timing and throttle sync right, by factory specs, that you do NOT run that motor. Great that you were able to rebuild that motor without a manual, but the adjustments for carb/timing are VERY model specific. Unless you can find somebody that has the manual that contains the information for your motor, you should really re-consider buying a manual. They are not very expensive particularly if you find one used. Good luck.
  12. #23
    Jun 2018
    Floating around
    Regarding the powerpacks; Ive owned my mota since new and over the years it stopped winding up as high. When it got to a lazy 5000RPM I figured it was time for a rebuild but the motor was fine it was the powerpacks that had slowly died in output. All cyls firing just not as well as should be. Replaced both power packs and instantly back to 6000+ RPM exact same set up. Playing around with engine height by moving up holes is WELL worth the effort if you dont want to wait for jack plate installation. As for sync carbs/timing that sure sounds crucial but never had to touch any of that on mine so cant help ya there. Hope some of this helps you out there are far more knowledgeable members here than me
  13. Thanks thunder77 thanked for this post
  14. #24
    Lake Coochiching, Ontario
    16' Baja, 4" manual plate. 55 mph gps with a 23 SRX. It was a bit slower but more useful all around with a 21 Renegade. Propshaft 3" below the pad, but it wasn't critical. I could go up or down an inch and not change more than 1 mph
    Same boat, 115 HO Etec. 67 with 26 small ear chopper and with 27 Hoss copy. Too much prop for anything but bragging. It ran 64 on the rev limiter with a 24 Raker, and it could accelerate and carry people. Just under 50 with a 17 Stiletto 4 blade that we used for skiing
    Same 115 Etec HO on a 19' flatbottom ski boat (J Craft). 52 with the 24 Raker, 48 with the 17 Stiletto.
    I need to sell the Stiletto and the Raker
  15. #25
    Sep 2017
    Ashland city tn
    I do agree that the motor needs b checked out , as in fuel and firing , he mite just b down a cyl and sum times hard to tell
  16. #26
    Jan 2015
    Quote Originally Posted by Merc 2.5 View Post
    This might explain his troubles:
    https://www.screamandfly.com/showthr...-130-v4-looper
  17. #27
    Australia
    hi Thunder. If you are running 80 km/h with a 17 inch prop you are revving way higher than 4900 rpm. Assuming you measured the speed accurately, you would have to be turning over 6300 rpm to run that speed with that prop. Check your tacho settings. If they are correct then you need a new tacho. You should be able to spin a 19 inch prop easily. 80 km/h is not bad for a cheetah with a 17. If you jack the motor as high as suggested then your ski boat will no longer be a ski boat. The cheetahs are not light so you will end up with a boat that is not that fast, but it won't pull the skin of your porridge. If your cav plate is level with the bottom then it is pushing through the water and is too low. If you were having problems with the cav plate an inch above, then you have another problem. Looks like you are in Qld. I am near Newcastle. Send me a private message if you would like to talk. Greg
  18. Thanks thunder77 thanked for this post
    Likes thunder77, FMP liked this post
  19. #28
    Apr 2017
    nunya business
    thanks greg, will mail you...
  20. #29
    Porridge! Good one!
  21. #30
    Jan 2015
  1. What speed boats can safely handle a 3.0l+ motor?
    By mxz in forum General Boating Discussion
    Last Post: 05-10-2013, 02:16 PM
  2. stove blower motor speed control size??
    By roadkill636 in forum The Scream And Fly Lounge
    Last Post: 01-26-2012, 07:14 PM
  3. Prop and Gearing Question
    By ls1velle in forum Props, Setup, and Rigging
    Last Post: 07-11-2009, 12:43 PM
  4. STV whats a safe motor size
    By jay1 in forum Props, Setup, and Rigging
    Last Post: 07-21-2007, 01:44 PM
